ip sla
Hello
I have configured a ip sla to an public ip with a route by an cellular interface.
When i start tracking it works view hours and then it goes down. After that i made a ping by hand by cmd it starts working.
Why does the cellular interface go down when ip sla made the ping and up when i made it by hand?
br
6 Replies 6
Under dialer interface config keepalive, this make dialer up when using ip sla.
balaji.bandi
post the config along with IP SLA information, what is the Logs you see when it go down ?
BB
track 40 ip sla 40 reachability
delay down 2 up 15
ip route 188.21.10.254 255.255.255.255 Cellular0/2/0
ip sla 40
icmp-echo 188.21.10.254 source-interface Cellular0/2/0
request-data-size 1400
frequency 5
ip sla schedule 40 life forever start-time now
the IP SLA configuration looks good. It is difficult to see what is going on without knowing what else is configured. Post the full running configuration (sh run) of your router...
just to make clarity here, you have only 1 connection even though you have IP SLA ping checking the Link going down automatically, you need to manually ping , that time link come up and work as expected for some time ?
why do you need to add route your WAN IP addres IP to cellular ?
can you post full configuraiton, what IP address you received from provider ? what IP you ping from what device ?
what is the Logs at the time when the link go down?
BB
depending on your router model, below are two sample configs, one without, and one with a dialer watch:
chat-script lte “” “AT!CALL1” TIMEOUT 60 “OK”
track 1 ip sla 1 reachability
delay down 10 up 20
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 4.2.2.2
ip sla auto discovery
ip local policy route-map SLA_RM
ip sla 1
icmp-echo 8.8.8.8 source-interface GigabitEthernet0
frequency 10
ip sla schedule 1 life forever start-time now
description ISP
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
ip virtual-reassembly in
interface Cellular0
ip address negotiated
ip nat outside
encapsulation slip
ip tcp adjust-mss 1000
dialer in-band
dialer string lte
dialer-group 1
async mode interactive
ip nat inside source route-map ISP_BACKUP interface Cellular0 overload
ip nat inside source route-map ISP_PRIMARY interface GigabitEthernet0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 track 1
ip route 0.0.0.0 0.0.0.0 Cellular0 10
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit icmp any host 8.8.8.8 echo
route-map SLA_RM permit 10
match ip address 101
set ip next-hop GigabitEthernet0
set interface Null0
route-map ISP_PRIMARY permit 10
match ip address 100
match interface GigabitEthernet0
route-map ISP_BACKUP permit 10
match interface Cellular0
dialer-list 1 protocol ip permit
event manager applet CLEAR_NAT
event syslog pattern “TRACKING-5-STATE”
action 1 cli command “enable”
action 2 cli command “clear ip nat translation forced”
action 3 cli command “exit”
With dialer watch (cellular always on)
delay down 10 up 20
ip dhcp pool LAN
ip sla 1
frequency 10
description ISP
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Cellular0
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer watch-group 1
set interface Null0
dialer watch-list 1 ip 5.6.7.8 0.0.0.0
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 1
event manager applet CELL_UP
event track 1 state down
action 1.0 cli command “enable”
action 1.1 cli command “configure terminal”
action 1.2 cli command “interface Cellular0”
action 1.3 cli command “no shutdown”
action 1.4 cli command “end”
event manager applet CELL_DOWN
event track 1 state up
action 1.3 cli command “shutdown”
