Router(config)#logging facility local6 - what does local6 mean?
shahul-hameed
Hi ALL,
Router(config)#logging facility local6 - what does local6 mean?.When i referred to the cisco site i found that Reserved for locally defined messages.But i don't it means Reserved for locally defined messages .Can anybody give me the exact explanation with the ref. to the link in the cisco site.
Earlier responses will be highly appreciated.
Shahul
10 Replies 10
jolmo
Level 4
Level 4
Hi Shahul
According to Cisco documentation,
If you are working with multiple network access servers , you can assign a different logging facility tag to each server. Syslog information can be collected and sorted into different files on the syslog server.
For example:
Assign local1 to NAS1
Assign local2 to NAS2
Assign local3 to NAS3
Assigning a different tag to each device enables you to intelligently sort and view syslog messages:
logging facility local7
This info has been taken from:
http://www.cisco.com/en/US/products/hw/univgate/ps509/products_maintenance_guide_chapter09186a008007cb7d.html#1020490
Hope this helps
shahul-hameed
can anybody plz give me the exact reply for the following
Router(config)#logging facility local6 - what does local6 mean?.plz specify the exact answer with the ref. of cisco link.
Your earlier response will be highly appreciated.
Shahul
Shahul,
I think 6 in local6 refers to the severity level of Syslog messages. If you set local6, then severity level 6 (information) and more severe (0-6) will be sent as log.
Refer link below for more info
http://www.cisco.com/en/US/customer/products/hw/contnetw/ps1894/products_tech_note09186a008009452b.shtml
Habeeb
Hi habeeb,
Thanks for your response.But this is not the answer.
Read my question.It doesn't deal with severity.
I want to know what does local6 mean ?
Router(config)#logging facility local6 - when this is configured in a router what does local6 mean?
Shahul
Haven't seen my previous answer ?
Hi Jolmo,
Iam sorry for not responding you as iam back to job only today.Thankyou verymuch for your immediate response.But your answer doesn't suite my question.
I need the answer for what does LOCAL6 mean?
Router(config)#logging facility local6 (local0-7 are availabe) But i need the exact answer for what does local6 mean?Can u plz help me out.
Shahul
Hi Shahul
According to documentation, I think local6 means the same as local7 or local0, so you can choose between them as you want (local7 is default).
I've seen some other info regarding UNIX syslog servers. It might help:
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_guide_chapter09186a0080341d18.html#wp1035347
Thanks for your response.But i haven't got the exact answer.Plz try to get me the exact answer.
Anybody plz help me in getting the exact answer.
Shahul
Its a label that allows a syslog server to differentiate between log messages and place them into the relevant log files.
So you might have a log on your server for local7 messages, and you might have a log on your server for local6 messages.
On a Unix machine this is configured in /etc/syslog.conf
The following is an extract from my syslog.conf file
local7.emerg;local7.alert;local7.crit;local7.err;local7.warning;local7.notice;lo
cal7.info;local7.debug /var/log/syslog_info
local6.Emergency;local6.Alert;local6.Critical;local6.Error;local6.Warning;local6
.Notice;local6.Info;local6.Debug /var/log/syslog_bluesocket
You can see that local7 messages are being logged to /var/log/syslog_info and local 6 messages sent to /var/log/syslog_bluesocket.
So to answer your question once and for all local6 is telling your router to tag all syslog messages as local6
Rgds
Paddy
hi shahul
In order to allow remote systems such as servers(unix variants) to succcessfully distinguish devices sending syslog messages to them, the logging facility concept was introduced. It uses values such as 0 (for kernel), 1 (for users)etc, to understand the source of its messages ie how the messages were generated. Furthermore it also has reserved values btw 16 and 23 for users to distinguish/classify any other generic device being used to generate and send these syslog messages. hence value 16 to 23 correspond with the local0 to local7 nomenclature. i.e 16=local0, 17=local1 18=local2......22=local6 etc. (Note: the local stands for "Locally Significant" facility names.)
