Router Configration for Internet Connectivity
born2winu2
Dear All
Below is the script, I am using for internet connectivity on 1841 router.The same scripts works fine at one place but dosent work on clients side.
Paragon>
Paragon>en
Paragon#sh runn
Paragon#sh running-config
Building configuration...
Current configuration : 1344 bytes
version 12.4
hostname Paragon
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip name-server x.x.x.x
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
archive
log config
hidekeys
bba-group pppoe global
interface FastEthernet0/0
ip address x.x.x.x x.x.x.x
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/50
encapsulation aal5snap
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username xyz password 0 abc
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer1 overload
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
webvpn cef
end
Paragon#
Plz help me out.
6 Replies 6
paolo bevilacqua
Hi, can you send output of "show interface dsl" to see if you're connected in first place, and mentioned the exact hardware used.
Then you don't need:
vpdn-group 1
request-dialin
protocol pppoe
Note what you call script is called configuration file in cisco terminology.
richard.gosling
The client will have a differnet CHAP or PAP usernamce and paasword, alos the PVC as well
No, They are in the same region with same ISP.
If you have 2 different DSL connections to the same site they will still have different CHAP Usernames
Have you done a debug on chap whilst trying to connect.
Richard is right.
I have a sbcgloabl acoount. Its at the same site same location 3 link on 3 diffrent routers all have diffrent chap hostname and password.
You may need to check this with the isp.
Pravin..
Thx dear All
My Problem was resolved.
Basically the problem was from the ISP side within the line.
