Router connect to the internet but LAN can't
JakobKorsholm
I have a 1921 router it connects to WAN just fine but my LAN won't connect to the WAN
Equipment:
Router 1921
Switch 2960
Client desktop. 192.168.65.10
ISP --> Router --> Switch --> client desktop
Router configuration
interface gigabitethernet 0/0
ip address dhcp
i
ip nat outside
interface gigabitethernet 0/1
ip address 192.168.65.2 255.255.255.0
IP nat inside
ip route 0.0.0.0 0.0.0.0 gigabitethernet 0/0 DHCP
ip nat inside source list 101 interface gigabitethernet 0/0 overload
access-list 101 permit ip 192.168.65.0 0.0.0.255 any
Hi there,
The LAN gateway IP address is 192.168.65.2 . Either adjust the LAN DHCP scope or change the static interface configuration on the client to reflect this.
cheers,
Seb.
the router configuration looks good. What is the IP configuration of the client, in particular, what is the default gateway used by the client ?
Client IP
192.168.65.10
255.255.255.0
192.168.65.1
Hi there,
cheers,
Seb.
It worked rookie mistake but thanks a lot
