Factory Reset on a Catalyst 3850 Switch Issue
roymccracken
I'm experiencing an issue that was referenced in this article from 2 years ago:
https://supportforums.cisco.com/discussion/11828266/password-recovery-catalyst-3850-switch
However, I'm not trying to do a password recovery. I need to do a factory reset because I set some "aaa" configurations on the switch and it wont let me in now. I can't even get a login or password prompt. I've rebooted, broken the boot sequence using the "Mode" button, did the "flash_init" and there is where I get stuck. A "dir flash:" shows the following list:
54209  drwx  4096       .
    2  drwx  4096       ..
54210  -rwx  2097152    nvram_config
54211  -rwx  74410468   cat3k_caa-base.SPA.03.02.00SE.pkg
54212  -rwx  2773680    cat3k_caa-drivers.SPA.03.02.00.SE.pkg
54213  -rwx  32478044   cat3k_caa-infra.SPA.03.02.00SE.pkg
54214  -rwx  30393116   cat3k_caa-iosd-universalk9.SPA.150-1.EX.pkg
54215  -rwx  18313952   cat3k_caa-platform.SPA.03.02.00.SE.pkg
54216  -rwx  63402700   cat3k_caa-wcm.SPA.10.0.100.0.pkg
54217  -rwx  1218       packages.conf
54218  -rw-  556        vlan.dat
54219  -rwx  57         express_setup.debug
Which brings me to my sticking point. I try to delete and/or rename the nvram_config and vlan.dat and it tells me that it is a read only file system and that the file is not deleted. What am I doing wrong?
Roy
johnd2310
Level 8
Level 8
Have a look at this doc:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/system_management/configuration_guide/b_sm_3se_3850_cg/b_sm_3se_3850_cg_chapter_01110.html#task_1021182
Set the switch to ignore startup config, boot switch and then you can delete the startup config
John
**Please rate posts you find helpful**
johnd2310
Level 8
Level 8
John
I have a similiar issue but the switch will not ingore the startup. I still keep getting default VLAN 1 may not have its name changed. I cant get past this point
VLANs are usually stored in vlan.dat file on flash drive. you should errase it if u do not want to keep names. you cannot remove default vlan 1 from any switches. Vlan 1 is default vlan on cisco switches and all ports are in vlan1 when sw is brand new - by default
hello,
Power start
Push Mode Button during 10 seconds
Four Orange lights
Release Mode Button
"flash_init" command
"boot" command
It's not enough to obtain a full reset factory.
After the boot, the old configuration is still here !
How to obtain a full reset factory ?
