Router Console Baud Rate not getting to 115200
Anand Narayana
Level 6
Level 6
we have a cisco 1700 series router, in that when i tried changing the baud rate in rommon, i could see only 9600,4800,1200,2400, but not the 115200, have any came across this situtation? i require this for faster image copying as if i select the 9600 option, i get a error message" request aborted by user"
amit-singh
Level 8
Level 8
Hi Anand,
If you are in rommon mode on 1700 you can use "tftp donload' feature instead of using the xmodem. I would suggest you to use the feature and do the faster file transfer.
Please refer the below link for more info :
http://www.cisco.com/en/US/products/hw/routers/ps221/products_configuration_guide_chapter09186a008007cd0e.html
HTH, Please rate if it does.
-amit singh
