Showing results forĀ
Search instead forĀ
Did you mean:Ā
Router CPU utilization
naveen_yummy
hi guys,
In my company we are using 2621 Router for the  connectivity between four plants...
Nowadays while i check the utilization of the CPU it reach 100%....due to that link connectivity get damn slow...
Is there is any tool or technique is used to get alert message when it crosses the 90% ...
thanks in advance
A.Naveen Kumar
snarayanaraju
Level 4
Level 4
Hi Naveen
You can use RMON feature of the router
Config)# rmon alarm 10 .1.3.6.1.4.1.9.9.13.1.3.1.3.60023 100 absolute rising-threshold 50 1 falling-threshold 10 2
(Config)#rmon event 1 trap xxxx description "Router CPU increased" log
(Config)#rmon event 2 trap xxxx description "Router CPU decreased" log
(Config)#snmp-server host 192.168.0.1
Where xxxxx is the snmp string . (eg.public)
sairam
hi sairam,
in this where i can mention mail id .....
Hi Naveen,
You can do this using EEM. Unfortunately I am not good in that to help you.
You can dig more on this
regards,
sairam
