router does not power on
RJAS27
Hi, I need help, I have a router 7200 Software (C7200P-ADVIPSERVICESK9-M), Version 12.4(15)T17, and after a power failure in the area it did not turn on anymore, what would be the fault?
6 Replies 6
Not sure what you have tried but you could do some troubleshooting like this:
1. Replace the power cable with a known good one.
2. Change the outlet its plugged into (make sure the outlet works with another device to make sure the outlet didn't get fried)
3. If you can change out the power supply in the router with a known good one, then try that too.
4. I am not assuming anything but make sure when the router is plugged in that the power switch is also turned on. While you shouldn't have to do this as the power switch should have remained "on" during the power outage and the router should have came back up when power was restored.
5. Lastly, and I cant believe I am saying this, but make sure there is actually power in the building and powering devices.
Phone call: Hey the router wont turn on. We don't have network?
Me after a bad storm: Do you guys have power in the building?
Them: No.
Me:.....
-David
Thank you but all those indications were already made but it did not work.
Do you know  of a list of providers ? for Venezuela,  Please....
Good to know. And sorry I do not.
And if all what I said was tested to include the power supply being replaced and still not working you may have to RMA the device if its fried.
RachelGomez161999
First, you should check if the power cord is plugged in properly and if it has enough power supply. If it doesn't, then you should plug it in again and wait for some time before trying to use it again.
Just follow these steps to power cycle your router and modem:
Step 1: Unplug the modem and router from the power outlet.
Step 2: Wait at least 15 seconds.
Step 3: Plug the modem back into the power outlet first, wait 1-2 minutes, then it’s time to power on the router.
Step 4: Wait for all panel lights on your cable modem to become green on before testing your internet connection.
Step 5: Connect to the network with your computer and test the internet connection. It’s always better to test this by connecting with an Ethernet cable if possible.
Greeting,
Rachel Gomez
Peter Paluch
Other friends here have already extensively listed the tests to be done so I am not going to bother you with them. I just have a few additional questions:
  • When connected directly to the console of the router, does anything get displayed in the terminal software at all when the router is power-cycled?
  • When the router is connected to the power, are there at least some signs of it being alive - some LEDs on, fans spinning... - or is it completely silent and dead?
Best regards,
Peter
Mark Elsen
                  - Attach a console , and or is anything (still) being displayed when the device is powered on ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
