router hardware
nasus32163
Community Member
I have a client with an Cisco2811. He now wants it to be a POE Router. Can he update the power supply and network module to make this happen or does he need to purchase a cisco2811-ac-ip?
11 Replies 11
Edison Ortiz
cisco2811-ac-ip is the part number for the power supply. No need to replace the router, purchase the POE card and power supply, you should be set
http://www.cisco.com/en/US/products/ps5853/products_data_sheet0900aecd8016bf0b.html
Thank you. Do you know if I need a power cable from the power supply to the NM slot?
The new power supply will replace the current one. The power supply is not installed in the NM slot.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/2800/hw/10_hw.htm#wp1048189
Yes, thank you, but how does the power get to the network module slot? is there a cable or is it built into the board?
The new power supply will provide the power. The PoE NM slot will know where to look for the power.
You have been very helpful, and just to clarify - for my boss - I don't need any cable from the power supply to the slot for the network module.
I don't have a router to look inside - but our client keeps speaking of a wire to the network module slot from the power supply.
Thank you again... sorry to push this.
The wire you're talking about comes with the ILP supply, it's not orderable separately. You need to connect it from the power supply to the ILP motherboard connector. Full details here:
http://www.cisco.com/en/US/products/ps5854/products_installation_guide_chapter09186a00802c5ad8.html#wp1161133
Andrew.
Excellent! Thank you so much!
no problem - don't forget to rate helpful posts (not just mine!)
Andrew.
How can I tell which power supply is installed without physical access to the router? Show Ver and Show diag don't show me.
Thanks!
Try "show environment" it should show something like this if is an AC-IP supply:
Router#sh environment
Main Power Supply is AC with -48V
-48V supply status: OK
-48V relay status: NON-ISOLATED
It won't show the -48V if it is not.
Rob
