Router History
is there a way to delete the history from a router
username/password of other users are displayed in here as clear text
Hello Vinesh,
I could not find a way to delete the history buffer either but this has been addressed recently. This behaviour should only affect 15.0(1)M images. Neither 12.4(14)T4 nor 15.1(3)T (and later) exhibits it anymore.
The bug is:
CSCth27938 'show history all' prints the password in clear text
Fixed in: 15.1(1)S 15.1(2.19)T
It is an internal bug so the description will not be displayed on CCO.
Cheers,
Rose
9 Replies 9
AKK
Can you please paste the output ?
garapoglou
Level 3
Level 3
If I got your question right, you need either to encrypt the passwords of those accounts, or delete them in case they're not used anymore.
Best regards,
Giorgos
#show history all , this command shows everything that has been done from start .
C2911#show history ?
  all  Display the full command history as in crashinfo
  |    Output modifiers
is there a way to remove this ?
Sure.  Log out and log back in.  The History will record commands for that session alone.
hi vineesh,
try these commands.
Router(config)#line vty 0 4
Router(config-line)#no history
Router(config)#line console 0
john
       i tried that already , set the history size to 1 etc , but its not clearing the history buffer.
Hello Vinesh,
The bug is:
Cheers,
Rose
Dear Vinesh,
Did you get the answer to your query? I also wants to clear history from XR Router but have no idea how to do, Can you please share if have any solution to that??
This command doesnt work, If this line is in the configuration then you will not be able to recall the previous command. Not a good suggestion.
