Nexus 9500 special characters in passwords on CLI, doesn't like % sign
richh
While trying to use the CLI and a script to automate the transfer of code, the CLI seems to have a problem with the % sign and will not allow it in the CLI.
copy scp://username:Exam>PlE23%P@10.5.113.116/nxos.9.3.9.bin bootflash: vrf management
See attached photo
We have tried adding a \ in front of it, quotes, nothing works. Would prefer to not change the password as it's used in many automated scripts and systems.
12 Replies 12
marce1000
 - Ref  : https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/system_mgmt/503_U3_1/b_Cisco_n3k_System_Mgmt_Config_503_U3_1/b_Cisco_n3k_System_Mgmt_Config_503_U3_1_chapter_0110.pdf
 >...Cisco Nexus 3000 Series passwords are case sensitive can contain alphanumeric characters only. Special
characters, such as the dollar sign ($) or the percent sign (%), are not allowed.
                                   On the long run it  is still better to get rid of it.
 M.
balaji.bandi
Looks for me bug, best is rather changing for password, create new user for this instance and use it. or raise an TAC case if you dont like to do.
BB
richh
Ok so actually tried a new password, got rid of the % sign, and now the CLI command doesn't connect.
If I simply do the copy SCP: BOOTFLASH: command and answer the prompts it works. When I try to submit the request with the single CLI command it fails to connect. ssh: connect to host 10.5.113.116 port 22: Connection timed out
richh
N9K01# copy scp: bootflash:
Enter source filename: nxos.9.3.9.bin
Enter vrf (If no input, current vrf 'default' is considered): management
Enter hostname for the scp server: 10.5.113.216
Enter username: <NAME>
The authenticity of host '10.5.113.216 (10.5.113.216)' can't be established.
ECDSA key fingerprint is SHA256:Z+N5YW2pppE52YqSaReGYiZNeAEff/EHKQjxCwcT2zA.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '10.5.113.216' (ECDSA) to the list of known hosts.
<NAME>@10.5.113.216's password:
nxos.9.3.9.bin 100% 1870MB 5.4MB/s 05:44
Copy complete, now saving to disk (please wait)...
Copy complete.
N9K01# copy scp://<NAME>:<PASS>@10.5.113.116/nxos.9.3.9.bin bootflash: vrf management
Warning: There is already a file existing with this name. Do you want to overwrite (y/n)?[n] y
how about for testing (is that works ?)
9K01# copy scp://<NAME>:<PASS>@10.5.113.116/nxos.9.3.9.bin bootflash:my.bin vrf management
BB
Nope, same results. Was a good idea though.
same results ? (can you explain more)
Do you have enough space locally ?
check with  - dir bootflash:
reading of your other post one of the IP you got success and copied ?
10.5.113.216
next one failing with below IP (are you trying 2 different SCP servers ?)
10.5.113.116
is this typo error of IP or  which one correct ?
BB
Wow.. Yeah I messed that up didn't I. .lol
Thanks for catching that. So I fixed the IP address to be 216 like it should and now it's re asking for my password even though it's in the CLI string.
Hope you resolve the issue with the correction, or are you still have the issue ?
if the resolved mark as resolved for the community users can use the same solution if they have one similar like yours.
BB
richh
Initial issue was resolved but now I am still unable to submit the download request without being prompted. Even though the info was already supplied in the CLI string.
the password it asked again you mean?
can you post full output.
BB
SWITCH_N9K01# copy scp://<NAME>:<PASSOWRD>@10.5.113.216/nxos.9.3.8.bin bootflash: vrf management
scp: /nxos.9.3.8.bin: No such file or directory
