Router Input rate is Uploading and Output rate is Downloading
getaway51
Level 2
Level 2
1)This happened after LAN traffic redirected somewhere else or not passing thru the router. Router WAN still connected.
0 input rate. Therefore i thought input rate is WAN port Upload rate. Output rate is WAN port Download rate. Am i correct?
5 minute output rate 463000 bits/sec, 215 packets/sec
2)I saw input rate is many fold higher than output rate.
IS router WAN port says Upload is 3620000 and download speed 966000?
SMTYU06#sh int gi/0/0
5 minute input rate 3620000 bits/sec, 724 packets/sec
5 minute output rate 966000 bits/sec, 435 packets/sec
168388008 packets input, 130299122018 bytes, 0 no buffer
Received 198 broadcasts (0 IP multicasts)
0 runts, 4 giants, 0 throttles
4 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
87905728 packets output, 24075745526 bytes,
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
1) If the interface is connected to the WAN device (towards your ISP), then input rate is download and output rate is upload.
2) It is common to see higher download speed than upload speed. In this case, you saw a 5 min average of 3620000 bits/sec download and 966000 bits/sec upload.
HTH,
Meheretab
HTH,
Meheretab
Tht is wht i thought. output rate is Upload and input rate is download rate.
But the data shows that it has 0 input rate when LAN traffic is redirected somewhere else.
It still has X output rate because the WAN is still connected to telco.
Could cisco input & output works the other way round? Also output packets in "sh int" are  crc, error.
