Router interface card problem
sagar.sarker
Does anyone know how can I find out if the interface card of router becomes faulty. I have got one HWIC-4ESW card that I can't see from the router.
Sagar
sagar.sarker
I am getting below information from show diag-
Router# show diag
WIC Slot 2:
Unknown WAN daughter card
Unknown EEPROM version 255
The router is 2811.
Any help in this regard is highly appreciable.
Sagar
Hello Sagar,
Unrecognized modules are usually either due to the IOS not being recent enough or due to hardware failure and the show diag is a good place to check about the module status. You can often get useful logs during bootup or insertion of the modules as well.
HWIC-4ESW requires 12.3(8)T as a minimum software.There is also a restriction that only 2 HWIC-4ESWs can be installed in one router.
If you have a supported IOS and you are not overstepping the above restriction, it looks like a possible hardware failure. I would recommend checking the module in another slot or if possible in another router to rule out slot/chassis failure and a reseat is useful as well in case the card is not pushed in properly.
I hope it helps.
Warm Regards,
Rose
