Router Internet access / Switch No internet access
Brenneman2385
Hello all,
I am new and working on my CCNA. I am extremely confused at this point and wanted to see if someone may be able to help me. I currently have a router (2611XM) that is configured and working properly. If I place a host connection on fa0/1 I have lan, and internet access. However when I place a connection between fa0/1 on my router to any port on my switch (2950) I do not have internet access. I have created vlan99 on ports fa0/1-8 and am currently working with this. If i connect a cable direct from my modem to any port on the switch I do have internet access on both vlan1, and 99. I think that it is a dns issue but can not figure it out. Any help would be appreciated. I have added my running config for the switch.
Thank you,
Devin
Current configuration : 1550 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch1
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport access vlan 99
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan99
ip address 10.0.0.99 255.0.0.0
no ip route-cache
ip default-gateway 10.0.0.1
ip http server
line con 0
password cisco
login
line vty 0 4
login
line vty 5 15
login
end
I think your laptop is getting the IP from DHCP and you configured wrong gateway address on DHCP pool.
ip dhcp pool MY_LAN
network 10.0.0.0 255.0.0.0
default-router 10.0.0.1
dns-server 1.1.1.1
Change it and try.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
10 Replies 10
Julio E. Moisa
Could you please share the router configuration, probably the Router's port is not configured with sub interfaces. If you are going to use one VLAN is ok but if you have 2 or more VLANs the switchport must be configured as trunk and the router interface with subinterfaces using encapsulation dot1q.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hello Julio,
I have added my running config on my router. I tried connecting fa0/1 from router to switch when everything was in vlan1 and still had the same issue. I then created the vlan99 on ports fa0/1 - 8 just to keep everything working on the vlan1.
Current configuration : 1264 bytes
version 12.4
hostname Router3.mylab
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.0 10.0.0.99
ip dhcp pool MY_LAN
default-router 192.168.0.1
dns-server 1.1.1.1
interface FastEthernet0/0
description ## INTERNET ##
ip address dhcp
ip access-group MY_WAN in
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
description ## MY LAN ##
ip address 10.0.0.1 255.0.0.0
ip nat inside
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list MY_LAN interface FastEthernet0/0 overload
ip access-list standard MY_LAN
permit 10.0.0.0 0.255.255.255
ip access-list extended MY_WAN
permit tcp any any established
deny tcp any any
permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Thank you for your help,
Devin
because on your router you have the following LAN ip address configured:
10.0.0.1 255.0.0.0
your default gateway that you have configured on your router is wrong. and needs to be 10.0.0.1 also
Please remember to rate useful posts, by clicking on the stars below.
Hello Dennis,
Sorry if I am missing something as I am still new to this. However the router works fine. FA0/1 has a static up of 10.0.0.1 and with a client connected directly to FA0/1 works with no issues. However when connecting that port to my switch I do not get internet access.
Thank you,
Devin.
when you connect to the switch and try to get onto the internet. does the client that you just connected get an IP address? and can you ping the 10.0.0.1 address?
Hello Dennis,
To be sure I did a ipconfig release / renew on client. IP given when connected to switch is 10.0.0.100 via dhcp. I can ping 10.0.0.1 with no issues, but can not ping the gateway at 192.168.0.1 on the client pc, or the switch.
However if I connect the client directly to port fa0/1 on the router that is assigned 10.0.0.1 I am able to reach the internet with no issues.
Thank you,
Devin
ip dhcp pool MY_LAN
dns-server 1.1.1.1
Change it and try.
Deepak Kumar
Deepak Kumar,
Hello Deepak,
Thank you for your input. I have made these changes, and am still having the same issue. Here is my current running config and issue.
Current configuration : 1261 bytes
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool MY_LAN
dns-server 1.1.1.1
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
ip nat inside
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
no ip http server
deny tcp any any
permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Thank you,
Devin
This is becuase you don't have any route on your router and I am not sure about your Gateway (192.168.0.1).
Add a route on router:
IP route 0.0.0.0 0.0.0.0 FastEthernet0/0
and check the route on your Gateway for the 10.0.0.0/8. If not then you have to add.
Deepak Kumar
Deepak Kumar,
Hello Deepak,
First let me say thank you to everyone that helped. I found that I had already and the router configured properly. I did not understand why it was not working and retraced my lines. I found that at some point during testing I had fa0/24 on the switch connected to fa0/0 on router therefor when I would disconnect main working line from switch I would loose access.
Sometimes it is good to start at 0 and work your way up.
Thanks again,
Devin
