Router is not able to find proper routes.
prabinchand
Hello experts !
i am doing dmvpn with dual hub but the problem is HO-primary router is all OK but HO-secondary router is malfunctioning. HO-secondary & primary & branch is configured with EIGRP broadcasting the tunnel and LAN network.
HO-primary & branch is getting the route from tunnel-1 but only the HO-secondary router is getting route from fa0/1.
Note: 1. Topology and HO-secondary route picture is attached below:
         2. No any config is done on ISP & LAN-switch, it is just a L2 link.
CONFIGURATION:
HEAD-OFFICE-PRIMARY:
HEAD-OFFICE-PRIMARY#sh run
Building configuration...
Current configuration : 1979 bytes
! Last configuration change at 15:02:37 UTC Tue Jan 18 2022
version 15.2
hostname HEAD-OFFICE-PRIMARY
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
interface Tunnel1
description ***PRIMARY - TUNNEL****
ip address 50.50.50.1 255.255.255.248
no ip redirects
ip nhrp authentication SECURE
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip tcp adjust-mss 1340
delay 100
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 123456
tunnel path-mtu-discovery
interface Tunnel2
description ***SECONDARY -TUNNEL***
ip address 60.60.60.1 255.255.255.248
no ip redirects
ip nhrp authentication SECURE2
ip nhrp network-id 2
delay 200
tunnel source FastEthernet1/1
tunnel key 456456
interface FastEthernet0/0
description ***PRIMARY ISP***
ip address 1.1.1.1 255.255.255.248
speed auto
duplex auto
interface FastEthernet0/1
ip address 192.168.10.1 255.255.255.0
standby 1 ip 192.168.10.10
standby 1 priority 110
standby 1 preempt
speed auto
duplex auto
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
description ***SECONDARY ISP***
ip address 2.2.2.1 255.255.255.248
speed auto
duplex auto
router eigrp 100
network 50.50.50.0 0.0.0.7
network 60.60.60.0 0.0.0.7
network 192.168.10.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
HEAD-OFFICE SECONDARY:
HEAD-OFFICE-SECONDAR(config)#do sh run
Current configuration : 1705 bytes
version 15.2
hostname HEAD-OFFICE-SECONDARY
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Tunnel1
ip address 50.50.50.3 255.255.255.248
no ip redirects
tunnel key 123456
interface Tunnel2
ip address 60.60.60.3 255.255.255.248
no ip redirects
tunnel key 456456
ip address 1.1.1.3 255.255.255.248
speed auto
duplex auto
ip address 192.168.10.2 255.255.255.0
standby 1 preempt
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
description ***SEDONDARY - ISP***
ip address 2.2.2.3 255.255.255.248
speed auto
duplex auto
router eigrp 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
BRANCH:
BRANCH#sh run
Current configuration : 2436 bytes
! Last configuration change at 15:05:28 UTC Tue Jan 18 2022
version 15.2
hostname BRANCH
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback1
ip address 192.168.100.100 255.255.255.255
interface Tunnel1
ip address 50.50.50.2 255.255.255.248
no ip redirects
ip nhrp map multicast 1.1.1.1
ip nhrp map 50.50.50.1 1.1.1.1
ip nhrp map 50.50.50.3 1.1.1.3
ip nhrp map multicast 1.1.1.3
ip nhrp nhs 50.50.50.1 priority 1 cluster 1
ip nhrp nhs 50.50.50.3 priority 2 cluster 1
ip nhrp nhs cluster 1 max-connections 1
ip nhrp nhs fallback 2
delay 10
tunnel key 123456
interface Tunnel2
description ***SECONDARY - TUNNEL ***
ip address 60.60.60.2 255.255.255.248
no ip redirects
ip nhrp map multicast 2.2.2.1
ip nhrp map 60.60.60.1 2.2.2.1
ip nhrp map 60.60.60.3 2.2.2.3
ip nhrp map multicast 2.2.2.3
ip nhrp nhs 60.60.60.1 priority 1 cluster 2
ip nhrp nhs 60.60.60.3 priority 2 cluster 2
ip nhrp nhs cluster 2 max-connections 1
delay 20
tunnel key 456456
description ***PRIMARY -ISP***
ip address 1.1.1.2 255.255.255.248
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
description ***SECONDARY -ISP***
ip address 2.2.2.2 255.255.255.248
speed auto
duplex auto
router eigrp 100
network 192.168.100.100 0.0.0.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
0 Replies 0
