A920-CONS-KIT-S vs. A900-CONS-KIT-S
config tea
Is there a difference between these two cables?
A920-CONS-KIT-S, found on this page:
https://www.cisco.com/c/en/us/td/docs/routers/asr920/hardware/installation/guide/b-asr920-ic-hig/b-asr920-ic-hig_chapter_0101.html
A900-CONS-KIT-S, found on this page:
https://www.cisco.com/c/en/us/products/collateral/routers/asr-920-series-aggregation-services-router/datasheet-c78-741006.html?dtid=osscdc000283
My guess is that they are interchangeable but just have different part numbers.
Can anyone can confirm this for sure?
Thanks.
balaji.bandi
yes its console cable can be used - i do not see the issue.
if the kit is Cisco router 920, then buy 920 kit is appropriate.
BB
balaji.bandi
BB
