Router ISR 1101-4P configuration. IP address DHCP from ISP. Not routing local network.
san4ez39
i have Cisco ISR C1101-4P router.
I have configured it to take DHCP address from ISP on WAN port.
Configured VLAN1 IP Address that i receive connecting my PC to LAN Ports.
Router can ping IP like 8.8.8.8 or any other and can ping FQDN. But my computer does not, i can only ping and traceroute to VLAN1 IP address and that is all.
Can someone help me in configuration? I suspect i need something like bridge maybe?
This is current router config:
version 16.9
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname R1
boot-start-marker
boot system flash bootflash:c1100-universalk9_ias.16.09.05.SPA.bin
boot-end-marker
no logging console
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone GMT 2 0
clock summer-time GMT+2 recurring last Sun Mar 2:00 last Sun Oct 2:00
no ip source-route
ip options drop
ip name-server 212.59.8.18 212.59.8.19
ip domain lookup source-interface GigabitEthernet0/0/0
ip domain name kalv.local
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 212.59.8.18 212.59.8.19
login block-for 120 attempts 4 within 120
login on-failure log
login on-success log
subscriber templating
license accept end user agreement
license boot level appxk9
no license smart enable
archive
 log config
  logging enable
  logging size 500
  notify syslog contenttype plaintext
  hidekeys
diagnostic bootup level minimal
redundancy
 mode none
vlan internal allocation policy ascending
 description ISP1
 ip address dhcp
 negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
 switchport mode access
interface GigabitEthernet0/1/3
interface Vlan1
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 dhcp
ip ssh rsa keypair-name MGMT
ip ssh version 2
logging trap notifications
logging origin-id hostname
logging facility syslog
control-plane
line con 0
 exec-timeout 15 0
 privilege level 15
 logging synchronous
 transport input none
 stopbits 1
line vty 0 4
 exec-timeout 15 0
 privilege level 15
 logging synchronous
 transport input ssh
line vty 5 15
 exec-timeout 15 0
 privilege level 15
 logging synchronous
 transport input ssh
end
Hello
You need to NAT for network vlan 1 users to be abe to reach the internet.
Int gig0/0/0
ip nat outside
int vlan 1
ip nat inside
access-list 1 permit 192.168.1.0 0.0.0.255
ip nat inside source-list1 interface gig0/0/0
Kind Regards
Paul
8 Replies 8
Hello
Int gig0/0/0
ip nat outside
int vlan 1
ip nat inside
Kind Regards
Paul
Thank you.
i know now where i was wrong. I tried this config before and it was not working:
Int gig0/0/0
ip nat outside
int vlan 1
ip nat inside
ip nat inside source-list1 interface vlan 1 overload
After i made changes and set your config - it started to work.
Hello @san4ez39
your setup is just basically the same as this OP apart from your “wan” connection is already attached to a isp rtr that is performing PAT on your behalf hence what you receive a rfc 1918 private ip address on the wan interface of your own rtr
Now if you are wanting to ADD additional lan subnets internally requiring internet access you will ALSO need to apply PAT on your rtr for those additional lan subnets.
remove
no ip name-server 192.168.2.13
no ip dhcp excluded-address 192.16.2.1
no ip dhcp pool LAN
no ip route 0.0.0.0 0.0.0.0 192.168.2.1
no access-list 1 permit
no ip default-gateway 192.168.2.2
add
ip name-server
ip dhcp pool LAN
dns-server 192.168.1.1
ip route 0.0.0.0 0.0.0.0 gig0/0/0 192.168.1.1
Kind Regards
Paul
Finally it's working!
I made the changes and also i add the
access-list 1 permit 192.168.2.0  0.0.0.255
Thank you for your help!!
Glad to hear it..
Kind Regards
Paul
zissisktm
I have the same router and i have no connectivity from all lan ports g0/1/0,g0/1/1,g0/1/2,g0/1/3.
The interface g0/0/0 its ok and can make successful pings outside.
What do you think that is the problem?
Thanks in advance
no routes, no nat? Hard to tell. Paste config please.
zissisktm
i am new to networking and i m little bit confuse.
This router its like soho routers with 4 Lan interfaces L2 and 1 wan interface L3.
The topology is from the Lan ISP modem/router to cisco c1101-4p wan port.
No connectinity from cisco LAN ports.
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
ip dhcp excluded-address 192.168.2.1
ip dhcp pool LAN10
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 192.168.2.13
domain-name xxx
crypto pki trustpoint TP-self-signed- xxx
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-xxx
revocation-check none
rsakeypair TP-self-signed-xxx
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
license udi pid C1101-4P sn
username xxx privilege 15 password xxx
redundancy
mode none
ip address 192.168.2.2 255.255.255.0
ip nat outside
negotiation auto
interface Vlan1
ip dhcp server use subscriber-id client-id
ip nat inside
ip http server
ip http authentication local
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
control-plane
line con 0
stopbits 1
line vty 0 4
login
transport input all
line vty 5 15
login
transport input all
end
Thanks for your replay
