Router lab question. Please help..
vazquez.jorge
Hello All,
I have 3 3600's at home all with T1-wic dsu cards (one router has two wics). I know that I can connect all of these routers to each other using a T1 crossover, my question is: Since I am preparing for the CCNA, then CCNP, can this set-up be used to practice all the routing protocols for each of the certs CCNA/CCNP? Any help is greatly appreciated.
JorgeV.
royalblues
Level 10
Level 10
Jorge,
Yes though 3 routers seem a bit less but should be good to understand protocols and stuff.
You can also use dynamips along with this to make a sort of complete lab
http://www.ipflow.utc.fr/index.php/Cisco_7200_Simulator
http://dynagen.org/
HTH, rate if it does
Narayan
