Router model 837
ciscodurme1
I tried to reset a pasword on a cisco adsl 37 router.
I followed the instructions posted in document:  Document ID: 12065
"Password Recovery Procedure for the Cisco 806, 826, 827, 828, 831, 836, 837 and 881 Series Routers"
After step 9
(Type  configure memory or copy startup-config running-config in order to copy the nonvolatile RAM (NVRAM) into memory)
I 'm stuck ; I get the following
Destination filename [running-config]?
dsl power-cutback 0
% Invalid input detected at '^' marker.
I have ios version 12.2(8).
Some advice?
Lieven H.
Rick Morris
Level 6
Level 6
I am not sure I understand what happen?
When following the doc you got to the point where you changed the password and saving to start-up, is that correct?
I am assuming this is the doc you are following
http://www.cisco.com/en/US/products/hw/routers/ps380/products_password_recovery09186a00800942bc.shtml
Is this error after you hit enter?
That's correct.
I hit ENTER   and then appears
I hit ENTER again and ten appears
dsl power-cutback 0
thx for your reply.
