Router-On-A-Stick configuration with a Firewall VM on ESXi and a Physical Switch ?!
huud
I have the following in my lab.
  • Physical Managed Switch
  • Physical ESXi server (connected to port 5 on switch)
  • Windows 10 VM running on ESXi Server (connected to vmnic1, port 6 on TP-Link)
  • OPNsense Firewall VM running on ESXi Server (connected to vmnic1, port 6 on TP-Link)
The OPNsense Firewall VM can do Sub-Interfaces, and VLAN tags.
I'm looking to have Router-On-A-Stick configuration where the Router VM is running inside ESXi while the switch is physical. All VLAN configurations will be on the physical switch. I have read that VLAN configurations must be done on either the physical switch or vSwitch, not both.
The way I see it the traffic flowing this case is as follows:
  • Traffic from Windows 10 VM will come to vSwitch11 (VLAN 11 vSwitch connected to vmnic1, port 6 on physical switch)
  • Traffic from Port 6 will go to Port 5 on physical switch (Port 5 is trunk and is vmnic0 in ESXi)
  • Firewall VM vNIC is vmnic0 will receive VLAN11 traffic
But my question is whether traffic will ever leave ESXi vSwitch ?
Thank You
LikeMyFloydPink
I'm willing to bet that - being as your question doesn't mention any Cisco device whatsoever, your mileage with this one is limited.
If I am wrong, however, and you just "forgot" to mention Cisco in your question above - which BTW, included the effort to name/describe products unrelated to anything that warrants a reply - a Starting Point would be:
-Create WAN vSwitch and WAN Port Group
-Create LAN vSwitch and LAN Port Group
-Google "how to opnsense on esxi physical switch" or some derivative thereof
----->> Here you go:
 https://search.brave.com/search?q=how%20to%20opnsense%20on%20esxi%20physical%20switch&spellcheck=0
-Before getting crazy with complex "potentially over your head" scenarios in your lab (Speaking from experience- trust me) get the fundamentals down (better)
-Maybe consider going to the VENDOR Specific forum/community/support site for the issue
LikeMyFloydPink
