Check License Status CISCO867VAE-K9
vyas.2020
I want to check license status of CISCO867VAE-K9 router, but I am not getting any command to check license.
Please find detail as below and command pushed. Even I have not found any output in SHOW TECH-SUPPORT
Router#sh inv
NAME: "867VAE-K9", DESCR: "867VAE-K9 chassis, Hw Serial#: XXX213XXXXX, Hw Revision: 0.3"
PID: CISCO867VAE-K9 , VID: V02 , SN: XXX213XXXXX
Router#sh version
Cisco IOS Software, C860 Software (C860VAE-ADVSECURITYK9-M), Version 15.2(4)M6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 19-Mar-14 18:40 by prod_rel_team
ROM: System Bootstrap, Version 15.1(4r)M3, RELEASE SOFTWARE (fc1)
XXX_Delhi uptime is 43 minutes
System image file is "flash:c860vae-advsecurityk9-mz.152-4.M6.bin"
Last reload type: Normal Reload
Last reload reason: power-on
Cisco 867VAE-K9 (BCM6368) processor (revision 0.3) with 234496K/26624K bytes of memory.
Processor board ID GMK213101W9
1 DSL controller
1 Ethernet interface
4 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
255K bytes of non-volatile configuration memory.
57344K bytes system flash allocated
Router#show lic?
% Unrecognized command
Router#show l
% Ambiguous command: "show l"
Router#l?
*lo=logout
lock    logging    login    logout
Router#lic?
Router#lic?
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#l?
l2    l2tp    l2tp-class    li-view
line    logging    login    login-string
Giuseppe Larosa
Hello @vyas.2020 ,
you have a device with the old style image
this means that the feature set is determined by the IOS file name that says Advanced Security package with strong encryption (k9)
Newer images have universal in the name and the features are enabled via licenses.
This is why show license is not supported in your device.
Hope to help
Giuseppe
Giuseppe Larosa
Hello @vyas.2020 ,
Hope to help
Giuseppe
Thank you Giuseppe Larosa for your quick responce.
You mean if I want to check the license status command, I need to upgrade the software image with latest one.
Software Download - Cisco Systems
balaji.bandi
You already have advnaced security image running "advsecurityk9"
BB
