Router Performance
ross.dewar
Can anyone suggest a reference for comparing performance of routers. I'm specifically interested in the throughput (pps, bps, ingress, egress etc). Is there a resource for comparing this kind of information across different platforms/models?
Thanks in advance.
paolo bevilacqua
Yes there is, here you go:
paolo bevilacqua
Addendum:
A slightly later rev of the same document. (Don't know if there are any differences.)
