Router Port , Protocol up even when cable is removed
raja d
I faced a strage issue as one of our router port cable was removed  from the router port but the Port status is showing as  up /up    which made our HSRP state  to active active causing an outage , The router we are usign is cisco 3845 and IOS is c3845-adventerprisek9-mz.124-8b.bin , are there any fix for this issue , is it an ios bug .can anyone help me out
Peter Paluch
Hello raja,
What kind of interface is that? Is it an Ethernet interface? If so, can you check whether the no keepalive command is configured on it? That would cause the port to remain up/up even if the cable is disconnected. Issuing the keepalive command will revert to the usual operation.
If it is not an Ethernet interface, or if there is no such command currently configured on it, would you mind posting its entire configuration? Thanks!
Best regards,
Peter
Peter Paluch
Hello raja,
Best regards,
Peter
is it loobpack Interface or Sub Interface..
Jawad
It is a Ethernet interface , i shall check the keep alive command and revert to u
Hi Peter Paluch
you were right the kee alive was not enabled now the issue is resolved thanks
