nat on a single router with 2 wan interfaces.
dino-chirico
Hi all,
I have a 1921 with 3 interfaces. One for the LAN and the other 2 are wan each with a public address. The 2 wan interfaces are used for redundancy. I would like to know how I can static nat the same port and inside address on both wan interfaces.
So if the request comes in on one or the other it works. I know if I do a static nat to one of the wan interfaces and then add the same port and inside address to the other wan interface it replaces the previous config.
cadet alain
use the extendable keyword at the end of your static PAT entries.
Alain
5 Replies 5
cadet alain
Alain
Hi Alain,
This is what i did. I normally use the interface, which in this case would have been g0/0 and g0/1 but the extendable command wouldnt show, so i used the actually ip address of the interface. is that correct. it isnt working
below is a the config
thanks
version 15.1
hostname lb-blackhole
boot-start-marker
boot-end-marker
enable password secret xxxx
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip bootp server
ip name-server x.x.x.x
ip name-server 8.8.8.8
username lifebroker privilege 15 secret 4 xxxxx
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Secondary link COPPER
ip address x.x.x.x 255.255.255.252
no ip redirects
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description Primary link FIBRE
ip address y.y.y.y 255.255.255.252
no ip redirects
ip nat outside
standby 10 priority 105
duplex auto
speed auto
interface GigabitEthernet0/0/0
description Inside LAN segment
ip address 192.168.0.251 255.255.255.0
no ip redirects
ip nat inside
standby 20 ip 192.168.0.185
standby 20 priority 105
standby 20 preempt delay minimum 10
standby 20 track 30 decrement 10
duplex auto
speed auto
interface GigabitEthernet0/0/0.6
encapsulation dot1Q 6
ip address 192.168.6.251 255.255.255.0
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source static tcp 192.168.0.115 80 y.y.y.y 80 extendable
ip nat inside source static tcp 192.168.0.115 443 y.y.y.y.158 443 extendable
ip nat inside source static tcp 192.168.0.25 980 y.y.y.y 980 extendable
ip nat inside source static tcp 192.168.0.176 3389 y.y.y.y 3389 extendable
ip nat inside source static tcp 192.168.0.120 9100 y.y.y.y 9100 extendable
ip nat inside source static tcp 192.168.0.176 56072 y.y.y.y 56072 extendable
ip nat inside source static tcp 192.168.0.115 80 x.x.x.x 80 extendable
ip nat inside source static tcp 192.168.0.115 443 x.x.x.x 443 extendable
ip nat inside source static tcp 192.168.0.25 980 x.x.x.x 980 extendable
ip nat inside source static tcp 192.168.0.176 3389 x.x.x.x 3389 extendable
ip nat inside source static tcp 192.168.0.120 9100 x.x.x.x 9100 extendable
ip nat inside source static tcp 192.168.0.176 56072 x.x.x.x 56072 extendable
ip route 0.0.0.0 0.0.0.0 x.x.x.x
i
access-list 101 permit tcp any any eq 3389
access-list 101 permit tcp any any eq 9100
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq 443
access-list 101 permit tcp any any eq 980
access-list 101 permit tcp any any eq 56072
control-plane
can you try adding a second static default route pointing out the other WAN interface
Alain
For that to work you need to assign two addresses two each of your servers (.115 and .116 in my example for the first server). With these addresses you can match on the return-traffic to direct the traffic out the correct interface:
interface Gig0/0/0
  ip policy route-map Gig0/0/0-IN
ip nat inside source static tcp 192.168.0.115 443 interface Gig0/0 443
ip nat inside source static tcp 192.168.0.116 443 interface Gig0/1 443
ip access-list extended Server1-IP1
  permit ip host 192.168.0.115 any
ip access-list extended Server1_IP2
  permit ip host 192.168.0.116 any
route-map Gig0/0/0-IN permit 10
  match ip address Server1-IP1
  set interface Gig0/0
route-map Gig0/0/0-IN permit 20
  match ip address Server1-IP2
  set interface Gig0/1
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
OK i worked out that the nat statements do work. The way i did the LAN side out to the active WAN is use ip sla with track. so if the gateway for the fibre WAN x.x.x.157 is reachable then it will use it as the default gateway if down and use the next weighted route y.y.y.237
see below config
redundancy
track 178 ip sla 178 reachability
ip address x.x.x.238 255.255.255.252
no ip redirects
ip nat outside
duplex auto
speed auto
ip address y.y.y.158 255.255.255.252
no ip redirects
ip nat outside
duplex auto
speed auto
no ip redirects
ip nat inside
ip local policy route-map DEFAULT-ROUTE-POLICY
ip route 0.0.0.0 0.0.0.0 x.x.x.157 track 178
ip route 0.0.0.0 0.0.0.0 y.y.y.237 200
ip sla 178
icmp-echo x.x.x.157
frequency 5
ip sla schedule 178 life forever start-time now
access-list 102 permit icmp any host x.x.x.157 echo
route-map DEFAULT-ROUTE-POLICY permit 10
match ip address 102
set ip next-hop x.x.x.157
set interface Null0
