Router Reboot
wasiimcisco
I have cisco 2851 with IOS Version 12.4(9)T5.
This router reboot frequently due to some unknow reason, This is my edge router and due to this reboot my network is suffering.
After reboot when i did the show version,
uptime is 16 hours, 23 minutes
System returned to ROM by bus error at PC 0x41A94C0C, address 0xD0D0D19 at 16:48
:43 UTC Mon Sep 1 2008
System image file is "flash:c2800nm-advipservicesk9-mz.124-9.T5.bin"
Please help me out how to solve this problem or this is a bug
satish_zanjurne
Level 4
Level 4
It is rebooting frequently in the sense, what's the interval of reboot, is it minutes/hours/days. ??
Can you attach the logs for this ??
Just see whether memory leak bug is there for this IOS ?
Monitor the memory consumption at regular intervals.If it is increasing & after reboot it is coming down, it has memory leak problem, you should be able to find bug releated to this .
If it is memory leak problem, you need to upgrade it to stable IOS.
awafe
Hello..There is a Cisco Software advisory out for this version of IOS.Unreliable..
Upgrade to 124-9.T6.bin.
Thanks..RL
The memory utilization is normal. My NMS report showing no abnormality in CPU/memory usage.
Router reload two weeks ago and then last night it reload.
I have configured the router as blocking device in cisco IPS and i think after configuring this i m started facing this problem.
why it is so
