router switch l3
madamasakis
Hi, i am dealing with a network problem.
Any ideas will be helpful.
Thanks.
paolo bevilacqua
2960g has small buffers, that can be the cause.
If you are happy with another switch model, use that.
rate-limit your copy so that it should not effect other servers in network.
Jawad
Jawad
