Router to Router HWIC TI DSU/CSU
Hello, I recently started setting up a ccna lab and one of my main objectives was connecting internet through the serial interface for a Hwic T1 dsu/csu module. I am stuck after the intial point of applying my static addresses and pinging for connectivity. I do not have a default-gateway set up. nor a ip route.
Here is my router 0-
Router0#show run
Building configuration...
Current configuration : 1802 bytes
! Last configuration change at 14:21:02 UTC Sun May 9 2021
version 15.8
hostname Router0
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 15
ip dhcp pool Practice2
network 192.168.138.0 255.255.255.0
default-router 192.168.138.1
dns-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid CISCO1921/K9 sn FTX1752835R
license accept end user agreement
license boot module c1900 technology-package securityk9
license boot module c1900 technology-package datak9
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.138.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
interface Serial0/1/0
description LINK to R2
ip address 10.2.2.2 255.255.255.252
router eigrp 1
network 10.0.0.0
network 192.168.137.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ipv6 ioam timestamp
access-list 1 permit any
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
Router0#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/41/60 ms
__________________________________________________________
Here is my Router2:
Router2#show run
Current configuration : 1871 bytes
! Last configuration change at 14:16:58 UTC Sun May 9 2021
version 15.8
hostname Router2
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
no aaa new-model
Router2#show run
version 15.8
hostname Router2
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool Router3
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
dns-server 8.8.8.8
no ip domain lookup
ip cef
no ipv6 cef
license udi pid CISCO1921/K9 sn FJC1925E16C
redundancy
no ip address
shutdown
no ip address
duplex auto
speed auto
ip address 192.168.100.1 255.255.255.0
ip nat inside
duplex auto
speed auto
description LINK to R1
ip address 10.2.2.1 255.255.255.252
ip nat outside
service-module t1 remote-loopback payload v54
router eigrp 1
network 10.0.0.0
ip default-gateway 192.168.137.2
no ip http server
ip nat source list 1 interface Serial0/1/0 overload
ipv6 ioam timestamp
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login
end
Router2#ping 8.8.8.8
Success rate is 0 percent (0/5)
PLEASE MUCH HELP IS NEEDED
I figured it out. The NAT inside command wasnt applied on the s0/1/0 interface. Thankyou for your quick responses.
5 Replies 5
Richard Burts
It looks like router0 is working and router2 is not. The most important issue on router2 is this
ip default-gateway is used when the router is operating as a host device (ip routing not enabled). When ip routing is enabled (the default on a router) then the default-gateway command is ignored. One way to fix the problem is to configure a static default route on router2.
Rick
I will try that. Thanks
balaji.bandi
For us to understand make a small network diagram of what ports connect to where?
Internet ----Router 0---Serial cable---Router X --Lan
Then Router 0 already doing NAT, so you no need to do NAt again on router X
make sure you need Routing working to reach Router 0, Router 0 routing going out to the Internet.
BB
