Router VPN Vlan access
JLVB83
Hey folks,
I've got my VPN setup I can make connections to the VPN, but I can't figure out the last steps required to allow the machines connected to my interface Virtual-Template1 to access my VLAN 3 here is my config as it stands:
Using 5367 out of 262136 bytes
! Last configuration change at 18:08:36 UTC Thu Nov 11 2021 by jlvb83
! NVRAM config last updated at 18:08:39 UTC Thu Nov 11 2021 by jlvb83
version 15.1
service password-encryption
service internal
hostname CISCO1921
boot-start-marker
boot-end-marker
enable secret 5 $1$rn7O$5kouMbw3c3zjSd64bALKa0
aaa new-model
aaa authentication ppp VPDN_AUTH local
aaa session-id common
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.10.10.1 10.10.10.20
ip dhcp excluded-address 10.10.20.1 10.10.20.10
ip dhcp pool CAMSNET
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 10.10.10.1
ip dhcp pool CLIENT_1
host 10.10.10.5 255.255.255.0
client-identifier 0100.1018.6f77.df
ip dhcp pool MAIN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
ip dhcp pool CLIENT_2
host 192.168.1.10 255.255.255.0
client-identifier 0164.9ef3.4de4.f6
ip dhcp pool MGMT
network 10.10.20.0 255.255.255.0
default-router 10.10.20.1
ip dhcp pool CLIENT_3
host 10.10.20.6 255.255.255.0
client-identifier 017c.0ece.e732.a4
ip dhcp pool CLIENT_4
host 10.10.20.5 255.255.255.0
ip domain name JLVB.CA
ip inspect WAAS flush-timeout 10
vpdn enable
vpdn-group L2TP
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
no l2tp tunnel authentication
license udi pid CISCO1921/K9 sn FGL160720QS
vtp domain NULL
vtp mode transparent
username jlvb83 password 7 1321051B1818052425253B32392F1A14025151060A19
username jlvbvpn privilege 15 password 7 123D171E011F0D0A242A37293F382B00134453510518
redundancy
vlan 2
name CAMS
vlan 3
name MAIN
class-map type inspect match-all IPSEC_CM
match access-group name ISAKMP_IPSEC
class-map type inspect match-any IN_OUT_CM
match access-group name IN_OUT_ACL
class-map type inspect match-all DHCP_CM
match access-group name DHCP
policy-map type inspect OUT_SELF_PM
class type inspect IPSEC_CM
pass
class type inspect DHCP_CM
pass
class class-default
drop log
policy-map type inspect IN_OUT_PM
class type inspect IN_OUT_CM
inspect
class class-default
drop log
policy-map type inspect OUT_IN_PM
class class-default
drop log
zone security outside
zone security inside
zone-pair security IN_OUT_ZP source inside destination outside
service-policy type inspect IN_OUT_PM
zone-pair security OUT_IN_ZP source outside destination inside
service-policy type inspect OUT_IN_PM
zone-pair security OUT_SELF_ZP source outside destination self
service-policy type inspect OUT_SELF_PM
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key cisco123 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set L2TP-Set2 esp-3des esp-sha-hmac
mode transport
crypto dynamic-map dyn-map 10
set nat demux
set transform-set L2TP-Set2
crypto map outside_map 65535 ipsec-isakmp dynamic dyn-map
interface Loopback1
ip address 192.168.2.1 255.255.255.0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
zone-member security outside
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
ip nat inside
zone-member security inside
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 3
ip nat inside
interface GigabitEthernet0/1.2
encapsulation dot1Q 2
ip address 10.10.10.1 255.255.255.0
interface GigabitEthernet0/1.3
encapsulation dot1Q 99
ip address 10.10.20.1 255.255.255.0
interface FastEthernet0/0/0
no ip address
no mop enabled
interface FastEthernet0/0/1
no ip address
interface FastEthernet0/0/2
no ip address
interface FastEthernet0/0/3
no ip address
shutdown
ip unnumbered Loopback1
peer default ip address pool l2tp-pool
ppp authentication ms-chap-v2 VPDN_AUTH
interface Vlan1
no ip address
ip local pool l2tp-pool 192.168.2.100 192.168.2.150
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 50.65.168.1
ip route 0.0.0.0 0.0.0.0 50.65.168.1 254
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
ip access-list standard IN_OUT_ACL
permit 192.168.1.0 0.0.0.255
ip access-list extended DHCP
permit udp any any eq bootpc
ip access-list extended ISAKMP_IPSEC
permit esp any any
permit ahp any any
permit udp any any eq isakmp
permit udp any any eq non500-isakmp
permit udp any any eq 1701
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 106D0817041313595C547E
transport input ssh
scheduler allocate 20000 1000
end
16 Replies 16
as far as I recall, that is related to the Virtual Template not being part of the inside zone. Try and add the below to the loopback interface:
interface Loopback1
--> zone-member security inside
I have tried that I also added the:
ip nat inside
with no luck
the NAT could be the problem. Try to make the changes marked in bold:
version 15.1
service internal
hostname CISCO1921
boot-start-marker
boot-end-marker
aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool MAIN
dns-server 8.8.8.8
ip dhcp pool MGMT
vpdn enable
vpdn-group L2TP
accept-dialin
protocol l2tp
virtual-template 1
vtp domain NULL
redundancy
vlan 2
name CAMS
vlan 3
name MAIN
pass
pass
class class-default
drop log
inspect
class class-default
drop log
class class-default
drop log
encr 3des
group 2
mode transport
set nat demux
interface Loopback1
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
no ip address
ip nat inside
duplex auto
speed auto
ip nat inside
no ip address
no mop enabled
no ip address
no ip address
no ip address
shutdown
interface Vlan1
no ip address
no ip http server
--> ip nat inside source list 101 interface GigabitEthernet0/0 overload
permit esp any any
permit ahp any any
--> access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
--> access-list 101 permit ip 192.168.1.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
transport input ssh
end
added still something stopping it I even tried
ip unnumbered Gi0/1.1
with no luck
Hey folks after some playing and testing what I have realized is i can ping VLAN adapters on my switches when using the VPN connection but can't seem to ping physical devices plugged int my switches and I'm not sure why this would be occurring.
JLVB83
I can only think that my problem might be that my vpn connection on my machine show's a default gateway of 0.0.0.0
JLVB83
After playing with it a bunch I removed
Interface GigabitEthernet0/1.1
ip nat inside
---->zone-member security inside
And found that my ping made it through so my firewall blocks the VPN connection from getting pings through not sure how to solve this any suggestions
since that post has become quite long, in summary, what problem is left ? And what does the configuration look like now (sh run) ?
The problem that I'm seeing is that when I'm connected to the VPN I can't ping/connect to my host on Vlan3 unless I remove the zone membership on my Gi0/1.1 interface on this current config:
Current configuration : 5535 bytes
! Last configuration change at 18:15:20 UTC Mon Nov 22 2021 by #####
! NVRAM config last updated at 17:59:05 UTC Mon Nov 22 2021 by #####
version 15.1
service internal
hostname CISCO1921
boot-start-marker
boot-end-marker
enable secret 5 ##################
aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp pool MAIN
dns-server 8.8.8.8
ip dhcp pool MGMT
ip dhcp pool VPN-1
network 192.168.2.0 255.255.255.0
vpdn enable
vpdn-group L2TP
accept-dialin
protocol l2tp
virtual-template 1
vtp domain NULL
username #### password 7 ##################
username ##### privilege 15 password 7 ###############
username ########### privilege 15 password 7 ####################
redundancy
vlan 2
name CAMS
pass
pass
class class-default
drop log
inspect
class class-default
drop log
class class-default
drop log
encr 3des
group 2
crypto isakmp key ############ address 0.0.0.0 0.0.0.0
mode transport
set nat demux
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
no ip address
ip nat inside
duplex auto
speed auto
ip nat inside
no ip address
no mop enabled
no ip address
no ip address
no ip address
shutdown
ip unnumbered GigabitEthernet0/1.1
peer default ip address dhcp-pool VPN-1
interface Vlan1
no ip address
no ip http server
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 ########
ip route 0.0.0.0 0.0.0.0 ######### 254
permit esp any any
permit ahp any any
ip access-list extended NAT
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
password 7 #####################
transport input ssh
end
try and configure the virtual template as 'ip nat inside':
--> ip nat inside
I had tried that already with no luck, I even tried adding the zone-member security inside with no luck
version 15.1
service internal
hostname CISCO1921
boot-start-marker
boot-end-marker
aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool MAIN
dns-server 8.8.8.8
ip dhcp pool MGMT
ip dhcp pool VPN-1
--> default-router 192.168.2.1
vpdn enable
vpdn-group L2TP
accept-dialin
protocol l2tp
virtual-template 1
vtp domain NULL
redundancy
vlan 2
name CAMS
pass
pass
class class-default
drop log
inspect
class class-default
drop log
class class-default
drop log
encr 3des
group 2
mode transport
set nat demux
no ip address
shutdown
--> interface Loopback0
description Gate for L2TP clients
ip nat inside
ip address dhcp
ip nat outside
duplex auto
speed auto
no ip address
ip nat inside
duplex auto
speed auto
ip nat inside
no ip address
no mop enabled
no ip address
no ip address
no ip address
shutdown
--> ip unnumbered Loopback0
ip nat inside
interface Vlan1
no ip address
no ip http server
permit esp any any
permit ahp any any
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
transport input ssh
end
Still the same unfortunately, the only time I can ping the host is when I remove zone membership from Gi0/1.1
what if you put the loopback and the virtual template in the inside zone as well ?
