11-17-2021 04:35 PM
I was looking up some factoids on this switch and came across a narrative that was comparing models and it mentioned the SG350X indeed not have PBR, but the SG550X Series did. When I go to official, though lacking in details, Cisco site it has like the array of SG Models and says PBR... I am just wondering if this can either be confirmed or denied of having PBR support.
Thank you.
11-17-2021 04:45 PM
check this video:
11-17-2021 07:06 PM - edited 11-17-2021 07:08 PM
it supports PBR. check attached image.
you should change display mode to 'advanced' at top right on switch GUI.
11-22-2021 03:50 PM
Thank you both.
I have looked over everything and they indeed reiterate everything I have configured, but still am having issues with PBR. This was why I was wondering if it indeed had PBR, because after setting up it did not work.
I have a template I used on my Catalyst and it works fine with no issues in the commands I typed in. I am wondering if maybe I am I putting it differently as I “translate” my Catalyst configuration via CLI to my SG350X configuration via GUI.
I have no doubt it is me overlooking something but I was wondering, even though I know Cat CLI is not the same as SG CLI, would I be able to input the same commands I did on Cat into SG CLI?
access-list 101 permit ip 192.168.32 0.0.0.15 any
access-list 102 permit ip 192.168.47 0.0.0.15 any
route-map ToInternet permit 10
match ip address 101
set ip next-hop 192.168.1.1
route-map ToInternet permit 20
match IP address 102
set ip next-hop 10.0.2.1
interface vlan 12
ip policy route-map ToInternet
The above is my Catalyst configuration in regards to PBR. (And works flawlessly).
