Dear All
Plz suggesst me the complied router for the below mentioned specs.,
high performance engine
modular design
compatibility with other end (ISP end)router
50 Kbps packet forwarding rate
WAN interface card with 8 E1 ports in single WIC
-sufficient flash memory(minimum 16 Mb)
-sufficient ram (minimum 256 MB)
-standard routing protool like RIP,OSPF,BGP
-monitoring of protocol statistics and performance of WAN bandwidth B40
-inrterface module support
LAN interface 10\100 base TX interfaces
WAN interface 8E1 line interface card
10\100 Mbps Ethernet interface card
-ACL packet filtering,NAT authentication audit DOS defense
-Policy based routing and low latency queuing
-WAN protocols
Multilink PPP
PPP
X.25
Frame Relay
-Comprssion payload and TCP/IP header
-congestion management
-Data Compression
-in activity time out
-security
-standard acces list and expanded access list B2B
Arjun
