Router problem
fernandacouto
Hi there,
I have a 1760 where I can not configure.
When the router initiates I see the following message:
device does not contain a valid magic number
Does anyone knows what is that?
Fernanda
Fernanda,
That error message indicates the flash does not hold a valid IOS - either corrupt or missing image. Copy a valid image to the flash using the instructions below, if you aren't already familiar with the procedure.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00801fc986.shtml
Sundar
Hi Fernanda
In addition to Sundar's comments you need to format your flash before copying up the new ios code onto your flash system..
regds
