Router with Ethernet port
New, sets for connection between HQ  and Branch Office(Migration). Our current router is cisco 1800 series with serial cable.
Please help me which router has Ethernet port connectivity
Francesco Molino
You want to buy a new router with Ethernet ports. What type of links you gonna have? How many port do you need?
Which features do you need?
You have the Cisco 1000 series and 800 series which can fit your needs maybe.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
It should be for DATA traffic
Is this model Cisco 892FSP suitable for data traffic?
Yes it is but again depending on what needs to be handled by the router
Francesco
Deepak Kumar
You can use the Cisco 800 series router.
https://www.cisco.com/c/en/us/products/routers/800-series-routers/index.html
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
