Router with multiple dialer - howto use specific one
packettracer86
Hello guys,
short technical question!
Setup:
one loadbalancer, one physical router, 4 ISP connections (4 dialer)
In some cases i want to use a specific dialer in other cases i want to loadbalance (round-robin/least connection.. not sure yet) connections to a "pool" of all 4 dialer.
So..
Is it possible to configure an IP ( like the router interface itself uses IP 10.10.10.1 and dialer[1-4] uses 10.10.10.[11-14] ) which i connect to in case i want to use a specific dialer?
Any other ways to get this thing work?
Greetings
I guess you could use policy based routing. In any case, if you want to use a specific dialer, you need to specify which traffic you want to send over that dialer. Which load balancer do you have ? Usually it lets you define rules similar to PBR on the Cisco router...
