Router ZBF - port forwarding
tomaszaniol
Hey, I have problem with port forwarding.
I want to achieve:
When I open web browser with 10.223.0.1:22222 on laptop it should be forwarded to 192.168.8.1:80 and admin page from LTE Router should be open.
Building configuration...
Current configuration : 4817 bytes
! Last configuration change at 09:25:23 SUMMER_ Tue Sep 4 2018
version 15.3
hostname Router
boot-start-marker
boot system flash:c800-universalk9-mz.SPA.153-3.M10.bin
boot-end-marker
aqm-register-fnf
logging console informational
no aaa new-model
clock timezone POLAND 1 0
clock summer-time SUMMER_POLAND recurring last Sun Mar 2:00 last Sun Oct 3:00
ip dhcp excluded-address 10.223.0.1 10.223.0.20
ip dhcp pool POOL
 network 10.223.0.0 255.255.255.0
 default-router 10.223.0.1
 domain-name xxxx.pl
 dns-server 8.8.8.8
 lease 0 2
ip domain name xxxx.pl
ip name-server 194.204.159.1
ip name-server 194.204.152.34
ip inspect log drop-pkt
ip cef
no ipv6 cef
parameter-map type inspect global
 log dropped-packets enable
 max-incomplete low 18000
 max-incomplete high 20000
class-map type inspect match-all CLASS_Inside_Outside_udp
 match protocol udp
 match access-group name Inside_Outside
class-map type inspect match-all CLASS_Outside_Inside_udp
 match protocol udp
 match access-group name Outside_Inside
class-map type inspect match-all CLASS_Outside_Inside_tcp
 match protocol tcp
 match protocol tcp
class-map type inspect match-all CLASS_Inside_Outside_icmp
 match protocol icmp
class-map type inspect match-all CLASS_Outside_Inside_icmp
 match protocol icmp
policy-map type inspect POLICY_Inside_Outside
 class type inspect CLASS_Inside_Outside
  inspect
 class type inspect CLASS_Inside_Outside_icmp
  inspect
 class type inspect CLASS_Inside_Outside_udp
  inspect
 class class-default
  drop log
policy-map type inspect POLICY_Outside_Inside
 class type inspect CLASS_Outside_Inside_tcp
  inspect
 class type inspect CLASS_Outside_Inside_icmp
  inspect
 class type inspect CLASS_Outside_Inside_udp
  inspect
 class class-default
  drop log
zone security INSIDE
 description INSIDE
zone security OUTSIDE
 description OUTSIDE
zone-pair security ZONE_Inside_Outside source INSIDE destination OUTSIDE
 service-policy type inspect POLICY_Inside_Outside
zone-pair security ZONE_Outside_Inside source OUTSIDE destination INSIDE
 service-policy type inspect POLICY_Outside_Inside
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface FastEthernet0
 description WAN LTE
 bandwidth 500
 ip address 192.168.8.2 255.255.255.0
 ip nbar protocol-discovery
 ip nat outside
 ip virtual-reassembly in
 zone-member security OUTSIDE
 load-interval 30
 duplex auto
 speed auto
 no cdp enable
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 no ip address
interface GigabitEthernet5
 no ip address
interface GigabitEthernet6
 no ip address
interface GigabitEthernet7
 no ip address
interface GigabitEthernet8
 description WAN
 ip address dhcp
 ip nat outside
 load-interval 30
 duplex auto
 speed auto
 no cdp enable
interface Vlan1
 description INSIDE
 ip address 10.223.0.1 255.255.255.0
 ip nat inside
 zone-member security INSIDE
interface Async3
 no ip address
 encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map ROUTE-MAP-FW-NAT interface GigabitEthernet8 overload
ip nat inside source route-map ROUTE-MAP-FW-NAT-LTE interface FastEthernet0 overload
ip nat inside source static tcp 192.168.8.1 80 10.223.0.1 22222 extendable
ip access-list standard FW-NAT
 permit any
ip access-list extended Inside_Outside
 permit ip any any
ip access-list extended Outside_Inside
 permit ip any any
logging policy-firewall rate-limit 10
route-map ROUTE-MAP-FW-NAT-LTE permit 10
 match ip address FW-NAT
 match interface FastEthernet0
route-map ROUTE-MAP-FW-NAT permit 10
 match interface GigabitEthernet8
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
 vstack
line con 0
 no modem enable
line aux 0
line 3
 modem InOut
 speed 115200
 flowcontrol hardware
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
Router#
ADP_89
I am not sure that's possible. You are trying to do a "destination nat" having the router 10.223.0.1 as outside local.
First you will need to change your nat command from "ip nat inside" to "ip nat outside" but this will change a little bit the game as routing will be done before nat translation on packet arrival. Given the fact that the local address has an administrative distance of 0 you have little chance to supersede it from the RIB.
My suggestion is to use an IP on the inside subnet as VIP for this connection, like 10.223.0.3 and then apply the following command:
"ip nat outside source static tcp 192.168.8.1 80 10.223.0.3 22222 extendable add-route". This will create an entry into the RIB causing packets going to 10.223.0.3 to be first routed and then natted.
Give it a go and let me know if this works
HTH,
ADP
I got this to work with "ip nat outside source static tcp 192.168.8.1 80 10.223.0.3 22222" witch will make a destination NAT on the outside interface after the normal source nat you already have on the inside interface.
Perfect. I am glad it worked.
Remember to mark the post as solved ;-)
ADP
rasmus.elmholt
Level 7
Level 7
Try it out and let us know if it works.
