Routes
cmadiam82
attached is the excisting network layout of our organization. i want to configure the remote site routers to be able to connect automatically to our DRC incase our CF router or CF network fails. does static routes can solve that one? pls advice.
Jon Marshall
How are your remote site routers peering with the MPS network ie. do you use static routes/BGP etc ?
What is the addressing for your DRC site, is it the same as the CF network ?
Jon
