Routing between 3G interfaces
colin.coe
Hi all
Amongst other things, I'm trying to get two Cisco 1941 routers with HWIC-1T and HWIC-3G-HSPA interfaces to use the 3G interfaces if the frame is down (as it is right now).
In the lab, I was not able to get these to use the 3G interfaces as a backup (i.e. backup interface cell 0/1/0) and I've not been able to workout the correct incantation for static routing either.
kununurra#show ip int br d1
Interface                  IP-Address      OK? Method Status                Protocol
Dialer1                    172.31.2.94     YES IPCP   up                    up
kununurra#traceroute 172.31.2.94
Tracing the route to 172.31.2.94
VRF info: (vrf in name/id, vrf out name/id)
  1 202.12.199.198 288 msec 208 msec 200 msec
  2 172.31.2.94 412 msec *  480 msec
kununurra#
wyndham#show ip int br d1
Dialer1                    172.31.2.95     YES IPCP   up                    up
wyndham#traceroute 172.31.2.95
Tracing the route to 172.31.2.95
  1 202.12.199.198 644 msec 636 msec 448 msec
  2 172.31.2.95 768 msec 916 msec 836 msec
wyndham#
Cellular 0/1/0 uses Dialer1
kununurra#show run | i route
ip source-route
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
ip route 0.0.0.0 0.0.0.0 Dialer1 254
ip route 172.31.2.0 255.255.255.0 Dialer1
ip route 192.168.3.0 255.255.255.0 Serial0/0/0
ip route 192.168.3.0 255.255.255.0 Dialer1 254
kununurra#
wyndham#show run | i route
ip source-route
ip route 192.168.2.0 255.255.255.0 Serial0/0/0
ip route 192.168.2.0 255.255.255.0 Dialer1 254
wyndham#
Given that when tracing to the IP address on the routers own Dialer interface, the first hop is 202.12.199.198 on both routers, how do I configure the routing?  As I'm not sure I'm being clear, normally devices on 192.168.2.x talk to 192.168.3.x via their routers serial interfaces.  When the serial (read fram relay) link is down, I'd like them to be able to talk over 3G.
Please note that I will still need to be able to access the router directly via the 3G interface as a failback/last resort.
TIA
CC
Richard Burts
CC
My first advice is to not try to use backup interface. There are other solutions that are much better.
I am not sure what is the issue with your incantation of static routing using the 3G. The floating static route which you have configured is a much better solution than backup interface. And given that we do not know much about how this router is configured it is hard to say for sure but it looks to me like these static routes and floating static routes should work. I am guessing that the 202.12.199.198 is an address of the provider gear that is handling your 3G connection. Can you ping some other destination in the Internet (and I would start by pinging IP addresses rather than names to avoid potential problems with DNS.
Rick
[edit] when I did a project which used 3G I just did dialer inband on the cellular interface and that worked pretty well. I would think that using a dialer interface should also work well.
Rick
Hi Rick
wyndham#sh ip int br
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         192.168.3.1     YES NVRAM  up                    up
GigabitEthernet0/1         unassigned      YES NVRAM  administratively down down
Serial0/0/0                192.168.57.2    YES manual down                  down
Cellular0/1/0              unassigned      YES unset  up                    up
Cellular0/1/1              unassigned      YES unset  down                  down
wyndham#ping 172.31.2.94
Sending 5, 100-byte ICMP Echos to 172.31.2.94, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 768/823/916 ms
wyndham#
This is in a private Telstra cloud so only our devices can talk to each other, I can't ping stuff on the net but these two routers can ping each other, and I can access them from the office, 2000+km away.
Here is a trimmed down show run:
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 192.168.3.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address 192.168.57.2 255.255.255.0
encapsulation frame-relay
clock rate 2000000
frame-relay interface-dlci 16 switched
frame-relay lmi-type ansi
interface Cellular0/1/0
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 1
dialer-group 1
async mode interactive
interface Cellular0/1/1
no ip address
encapsulation ppp
interface Dialer1
ip address negotiated
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string gsm
dialer persistent
dialer-group 1
ppp chap hostname username
ppp chap password password
ip forward-protocol nd
no ip http server
no ip http secure-server
dialer-list 1 protocol ip list 1
The other router is basically the same, just with appropriate IP address changes.
CC
Yay!  I've got it working.
I setup a GRE tunnel with the dialer interface being the source on the other router's dialer IP being the destination.  Now I can traceroute between the 192.168.2.0 and 192.168.3.0 networks!
CC
CC
I am glad that you got it working. Congratulations on finding a solution. Thanks for posting back and updating the status so that we know that it is solved.
Rick
Rick
