Routing between our offices
Greg Maaaag
Hello!
WE've got 2 router between our offices
Here're configs:
version 15.2
service password-encryption
hostname Office_Sad
boot-start-marker
boot system flash:/c1900-universalk9-mz.SPA.152-2.T.bin
boot-end-marker
no aaa new-model
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip dhcp excluded-address 192.168.4.1 192.168.4.99
ip dhcp pool pool
network 192.168.4.0 255.255.255.0
default-router 192.168.4.12
dns-server 192.168.240.100
ip flow-cache timeout active 1
ip domain name office
ip cef
crypto pki trustpoint TP-self-signed-1150895397
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1150895397
revocation-check none
rsakeypair TP-self-signed-1150895397
crypto pki certificate chain TP-self-signed-1150895397
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31313530 38393533 3937301E 170D3133 30313137 31343235
  30375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 31353038
  39353339 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CF84 99BF3D83 04319C0F C0A0CB94 995F790E 1CB35E02 E61DB82D C7F802D6
  2CED4FB4 15F23851 CC2B34CD 4D5F361B 7A30D2F8 358E1FDC C249302F 3610C37D
  3785084A 11313A21 51AA45B8 82E7FB12 6F193865 78169750 29C395CF 417CECFF
  CDF01641 4B8C76C7 4983BC23 500D17F4 AC10A7E5 9AD9603C 4FC8CF74 407562C7
  308F0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14448C26 307AF176 92606BCB DFAB80EB 15780CD7 C7301D06
  03551D0E 04160414 448C2630 7AF17692 606BCBDF AB80EB15 780CD7C7 300D0609
  2A864886 F70D0101 05050003 8181009B 0524D36D FCD95DF3 3C8686F3 AD1A5671
  C9E5D263 9019CC62 2DDCCD36 DA653B33 3507E515 CEAC360F 12581860 E984A649
  322BF087 FB33B1C1 28DCEA0A EF1E1F24 C583D51B C10C1902 17A2B3FB 5B203965
  1931F5D9 6076F9E4 C96621E3 8858A2FE F0822C7A 19171797 A44FE809 E8446C71
  C37495F1 60D53B93 21D8F3B5 F16E6B
        quit
license udi pid CISCO1941/K9 sn FCZ164791BH
license boot module c1900 technology-package securityk9
username b1_adm privilege 15 secret 5 *
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 89.104.*.* 255.255.255.0
ip flow ingress
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
crypto map vpn
interface GigabitEthernet0/1
ip address 192.168.4.12 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-export source GigabitEthernet0/1
ip flow-export version 5
ip flow-export destination 192.168.4.26 9996
ip nat pool Trassir 192.168.4.23 192.168.4.23 netmask 255.255.255.0 type rotary
ip nat inside source list 100 interface GigabitEthernet0/0 overload
ip nat inside destination list 105 pool Trassir
ip route 0.0.0.0 0.0.0.0 89.104.*.225
ip route 192.168.9.0 255.255.255.0 89.104.*.229
ip sla 1
icmp-echo * source-interface GigabitEthernet0/0
threshold 2
timeout 2000
frequency 5
ip sla schedule 1 life forever start-time now
access-list 100 permit ip any any
access-list 105 permit tcp any any range 3080 3084
access-list 105 permit tcp any any eq 8080
access-list 105 permit tcp any any eq 4433
snmp-server community mon_cacti RO
snmp-server ifindex persist
snmp-server enable traps entity-sensor threshold
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
and another:
no service pad
hostname PaulShark-Sad
boot-start-marker
boot system flash:/ios.bin
boot-end-marker
enable secret 5 *
no aaa new-model
memory-size iomem 10
ip dhcp excluded-address 192.168.9.1 192.168.9.100
ip dhcp pool pool
network 192.168.9.0 255.255.255.0
default-router 192.168.9.12
dns-server 192.168.240.100 82.112.184.34
ip dhcp pool reserv
host 192.168.9.99 255.255.255.0
client-identifier 01b4.b52f.f11b.83
client-name hp400_ps
domain-name office.local
no ip domain lookup
ip cef
no ipv6 cef
license udi pid CISCO881W-GN-E-K9 sn FCZ1638C56X
ip tcp synwait-time 5
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address 89.104.*229 255.255.255.240
ip flow ingress
ip flow egress
ip nat outside
ip route-cache same-interface
duplex auto
speed auto
crypto map vpn
interface wlan-ap0
description Service module interface to manage the embedded AP
ip address 192.168.254.93 255.255.255.0
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface Vlan1
ip address 192.168.9.12 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
no ip http server
ip flow-export source FastEthernet4
ip flow-export destination 89.104.*.230 9996
ip flow-top-talkers
top 10
sort-by bytes
cache-timeout 100
ip nat inside source list 100 interface FastEthernet4 overload
ip route 192.168.4.0 255.255.255.0 89.104.*.230
access-list 100 deny   ip 192.168.9.0 0.0.0.255 192.168.181.0 0.0.0.255
access-list 100 deny   ip 192.168.9.0 0.0.0.255 192.168.240.0 0.0.0.255
access-list 100 permit ip 192.168.9.0 0.0.0.255 any
access-list 102 permit ip 192.168.9.0 0.0.0.255 192.168.181.0 0.0.0.255
access-list 102 permit ip 192.168.9.0 0.0.0.255 192.168.240.0 0.0.0.255
no cdp run
route-map vpn permit 10
match ip address 102
set interface FastEthernet4
line con 0
exec-timeout 30 30
privilege level 15
password 7 *
logging synchronous
login
line aux 0
line 2
no exec
transport input all
line vty 0 4
privilege level 15
password 7 *
login local
transport input all
end
So just simple scheme: two routeres,
first LAN: 192.168.4.0/24 WAN: 89.104.*.230
second: LAN: 192.168.9.0/24 WAN: 89.104.*229
I added static routes for their subnets, ping from their external interfaces reache destination networks, for example i ping from 89.104.*.230 local ip 192.168.9.12 and it's okay.
But when i try to ping from 192.168.4.4 ip 192.168.9.12 it doesn't go
Why?
12 Replies 12
Hi Greg
If I'm not thinking completely insane right now: How would this work?
If you are on a host in the 192.168.4.0/24 subnet and you are trying to reach the a host in the 192.168.9.0/24 subnet, you will have to traverse the internet. The packet will have a destination IP address of 192.168.9.12 which is a private IP-address, and as you may know; those are blocked on the internet.
Or have I missed something?
Yes you are right, but not internet, this routers are in one ISP vlan from one subnet.
I can give for this routers secondary IPs from 192.168.181.0/24 subnet, for example first router secondary external ip 192.168.181.13 and another is 192.168.181.14, i can ping from any subnet their external IPs so they see teach other.
How can I make 192.168.4.0/24 reach 192.168.9.0/24 ?
Greg,
Do you have a discrete point-to-link between the two offices? A link that does not go to an ISP of any sort?
Because if you are still going through some sort of an ISP then you are going over a public interface of some sort and as was stated above by Henrick, you cannot do that because of the rule about private IP space.
ISP gives us native L2 without any MLPS or something. I can plug into wan port with local ip in both offices and they'll see each other.
Right now it looks like this:
All routers connected to vpn-conentrator on vyatta via ipsec with aes128, md5.
I want to switch VPN to static routing, starting from this routers:
Access lists 100 and 105 is used to determine which source and destinations are translated and should include
"access-list 100 deny ip 192.168.9.0 0.0.0.255 192.168.4.0 0.0.0.255" or the reverse so that traffic is not NAT'd coming in or out on both sides
A "permit TCP" does not include ICMP but a "permit IP" does or you can have a seperate permit ICMP statement.
Test by doing a "telnet 192.168.4.4 8080" to test a TCP port.
Try capturing the traffic to see if it is getting NAT'd or do a "show ip nat translation | i 192.168.4.4" to see inside and outside addresses.
shouldn't router look in the routing table, see route 192.168.4.0/24 to 89.104.2.230 and route all traffic to that hop with acl permint any any ?
Hello again!
I must say it's really hard to understand your topology. You say you have secondary IP-addresses, but I can't see any... But maybe this will fix you issue.
So you have a static default route to find the other subnet, that way the router knows where to send the packets, but does your ISP know where that subnet is located? If the ISP doesn't have static routes for those subnets, it will not find them.
What I think you could try is to make a simple logical tunnel between the two routers.
R1:
interface tunnel 1
description Tunnel to R2
ip address 192.168.255.1 255.255.255.0
tunnel source
tunnel destination
R2:
interface tunnel 1
description Tunnel to R1
ip address 192.168.255.2 255.255.255.0
tunnel source
tunnel destination
And then when you have done this, you will need to redirect your static routes so they points to the tunnel interface, or start using a dynamic routing protocol.
The access lists that I am refering to are used to describe which traffic gets addres translated with the "ip nat source list" command.  This is assuming that you want the traffic going to the other side to retain it's private address and that the network between them allows private addresses.  The deny says "don't NAT this traffic to the outside interface IP address".
The post above which creates GRE tunnel will accomplish the same thing with a little processing and packet encapsulation overhead.  This affects the maximum size packet (usually fixed at 1500 on the interfaces) that can be sent from either side.  There can be packet loss issues also if the "don't fragment" bit is set and the packet is too large.
2 glenn
thanks, i'll try to do it today in the evening and see if it work)
as I said the main point is if we change ISP and, for example, new ISP well just provide us different subnets with different gateways, we need all this topology get work somehow...
2 Henrik
Thank you for the answer!
Yes, your topology is very difficult because our present ISP gives us native L2 using some kind of vpn cloud for all our branches, we can use any IPs of ISP's vlan on any branch and if we will change ISP, we'll have lots of problems.
So first of all I decided to switch from VPN to static routing without ipsec and the switch to dynamic routing via OSPF..
can this interface tunnel go down like vpn tunnel?
The tunnel interface will go down if the physical interface is down. You can run IPsec over GRE and still run OSPF over the tunnel eventhough you run IPsec.
I want to take away ipsec tunnel because it somehow goes down....
I started cacti with snmp of cpu, errors and traffic
I strated netflow with ManageEngine Netflow Analyzer
Somewhy tunnels between byatta and other branches go down. Today tunnel between vyatta and 1st branch went down, yesturday between vyatta and 4th branch, there is no schema and no resons like high cpu or high traffic load....
I can't understand why it goes down and that's why i decided to take away ipsec
