Routing, connecting two different networks
Mohax
Hi, Im kind of new to this and im trying to do my best, I made the the two network setup and everything is fine. Configured the VLANS , trunk and access ports and the router on a stick. However I'e tried many routing methods in order to connect both networks but it just doesn't work, Anyone knows what's the problem and a possible solution for this?
I've attached the pkt as a compressed zip file
Thanks a lot
2 Accepted Solutions
luis_cordova
Hi @Mohax ,
You could compress your exercise and attach it to be able to examine the configurations.
Hi @Mohax ,
If your exercise is formulated in PacketTracert (.pkt), it is enough to occupy a program like winrar, winzip, 7zip, etc.
Once compressed, you can attach it.
8 Replies 8
luis_cordova
Hi @Mohax ,
Im sorry but how can I do that?
thanks
Hi @Mohax ,
Dennis Mink
can you tell us where to where you are attempting traffic. ips, also do a traceroute and see where the traffic does, and on the last good hop. do  a sh ip route
Please remember to rate useful posts, by clicking on the stars below.
With the default routing method Im trying to get traffic from laptop to another one in the different networks. Im kind new so i don't really get the terms you're mentioning
Are you talking physical laptops using gns3 or the laptops within gns3?
If you could take a look at the ptk file thank you
Hi @Mohax ,
I have sent you the corrected exercise by mail.
