Routing fast ethernet interfaces between Cisco 2811 and 1841
chrislgicale
Hello Guys,
Is it possible to route fast ethernet interfaces of Cisco 2811 and Cisco 1841 routers? Do I have to check for its compatibility or some additional configs that make them able to route, as well as ping.
Thank you.
Chris
17 Replies 17
Hi Rick,
Ethernet adapter Local Area Connection:
   Description . . . . . . . . . . . : Intel(R) 82579LM Gigabit Network Connection
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::c08a:ab20:c99c:8834%11(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.100.100(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Wednesday, February 12, 2014 7:24:52 AM
   Lease Expires . . . . . . . . . . : Thursday, February 13, 2014 7:24:52 AM
   Default Gateway . . . . . . . . . : 192.168.100.253
   DHCP Server . . . . . . . . . . . : 192.168.100.3
   DHCPv6 IAID . . . . . . . . . . . : 285221324
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-16-FB-FE-B6-00-21-CC-BB-A5-77
   DNS Servers . . . . . . . . . . . : 192.168.100.3
                                       192.168.1.6
   NetBIOS over Tcpip. . . . . . . . : Enabled
The PING your are trying to confirm are all correct.
Thank you and hope you can help me guys.
Chris
Chris
Thank you for the additional information. As a test would you try this and tell us if the behavior changes
interface FastEthernet0/1
no service-policy input Block_Traffic
Rick
Rick
chrislgicale
Hi Rick,
Thanks for helping me. I will let you know once I configure that.
Chris
