Routing from PC on network to ISP on Cisco 851
mrphilli1
I am a newbie to Cisco router configs. I have just purchased a CISCO 851-K9. I have a ISP which gives me a static IP and used PPPOE. I can connect to my ISP and they can see me successful connection. From the CISCO SDM software I can ping outside IP addresses but I can not ping them from my PCs on the internal network. It seems like I'm not getting routed out. I have included my router show config and my ip route info below. I'm hoping I've just made a simple goof someone can help me with.
Many thanks! Mark
ip subnet-zero
no ip source-route
no ip dhcp use vrf connec
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp pool sdm-pool1
import all
network 10.10.10.0 255.255.255.0
dns-server 216.x.x.22 209.242.0.2
default-router 10.10.10.10
ip cef
ip tcp synwait-time 10
no ip bootp server
ip domain name home.com
ip name-server 216.x.243.22
ip name-server 209.x.0.2
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $FW_OUTSIDE$$ES_WAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.10 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
ip tcp adjust-mss 1412
interface Dialer0
ip address 209.xxx.xx.x 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname markp
ppp chap password 7 XXX
ppp pap sent-username markp password 7 xxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
dialer-list 1 protocol ip permit
markp#show ip route
candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
C 209.xxx.xx.x/24 is directly connected, Dialer0
S* 0.0.0.0/0 is directly connected, Dialer0
7 Replies 7
rajinikanth
Level 3
Level 3
In ur sh ip route command
i dont see 10.10.10.0 network.
Why do u have the dialer-list 1 protocol ip permit command
and can you please provide me this command output
sh ip interface brief
Raj
I used the SDM express to configure so these are the options it configured for me. I told the WAN that I had a static IP address and it set it up as dialer0.
Thanks much for the help,
Mark
Here is the command output:
markp#sh ip interface brief
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0 unassigned YES unset up down
FastEthernet1 unassigned YES unset up down
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up down
FastEthernet4 unassigned YES NVRAM up down
Vlan1 10.10.10.10 YES NVRAM up up
Dialer0 209.xxx.xx.s YES NVRAM up up
I want to know to what port ur connecting ur pc to on ur router.
and whose IP is 10.10.10.1
Before that can u add this static route in global config mode
markp(config)#ip route 209.xxx.xx.x 255.255.255.0 10.10.10.10
Tell me if it works
Raj
I'm connecting my pc to lone of the LAN ports marked as FE0, FE1, FE2 and FE3. The WAN cable is hooked to my static IP which comes off of my ISP into my house. The connection is PPPOE but it's fixed wireless on the roof not DSL or Cable.
gives me this error:
%Inconsistent address and mask
Mark
I can ping hosts outside my network while using the command line interface of the router, but I can not ping any host outside from any PC that's connected to one of the LAN ports on the router. What do I need to do to enable the routing from my 10.10.10.10 router address out to remote networks like my ISP DNS server address?
Mark
Mark,
What you are missing here is NAT on the router. Your 10.x.x.x network is a private address space and is not routable in internet. So you need to translate that to your public ip assigned to you by your ISP.
int dialer 0
ip add
ip nat outside
int vlan 200
ip add
ip nat inside
ip nat inside source list 101 interface dialer 0 overload
access-list 101 permit 10.0.0.0 255.0.0.0
In this acl i am permitting the entire 10.0.0.0 range, which you dont need to. You should customize the ACL according to the internal lan subnets that you have. If you have multiple lan segments, you will need to add multiple acl statments, each line matching the corresponding lan subnet.
Sankar
PS: please remember to rate posts!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Yes I used SDM to enable basic NAT and that did the trick. This router is blazing compared to my old SOHO one. Thanks much for all the suggestions!
Mark
