routing help
bluesea2010
Level 5
Level 5
Hi, I have two different sites, but I have only two firewalls, so want to deploy active-standby,
if site b internet traffic has to go through site b active fw , if site a fw fails ,site b fw should be active and all internet traffic has to go through the site b
How can I do this
What are the pros and cons
8 Replies 8
my suggestion is to use 2 firewalls independently on 2 sites. you can use route metric customizations to do route prioritization.
Good luck
KB
Thanks . if site A both firewall failed , how  can  I  send the  internet traffic to site b .
And If site A  wan connection failed but firewall active , how can I send to site B
you need 2 internet connections for 2 sites.
Good luck
KB
If no redundant isp then?
if sites are placed in distant places, you must have 2 connections for both sites. because if 1 site goes down, all the links are unusable. so you need secondary set of links to get access.
Good luck
KB
I think my question was not clear , the connectivity between sites are ok and both sites firewall are up.But in site b the isp is down .
So I want all internet traffic from site a to site b.
How can I do that
how are the sites connected to the firewalls ? The easiest would probably be to implement SLAs on boyh sides that track the availability of the firewalls, and if there is no reachability, simply reroute all traffic using static routes...
Hello
If a site isp link fails then how do you connect to the other site?
If you don’t have any resilient connection the site that’s fails is isolated, As such you cannot have any form of HA redundancy.
Kind Regards
Paul
