07-09-2014 11:21 AM - edited 03-04-2019 11:19 PM
Hi, I think I'm having a NAT issue with the traffice coming from a GRE tunnel.
I have the following scenario:
Branch: Lan:192.168.96.0/24 WAN:192.168.0.34/30
Central site: Lan: 192.168.1.0/24 WAN: 192.168.0.2/30
Branch config:
interface Tunnel3 bandwidth 10000000 ip address 10.96.96.1 255.255.255.252 ip mtu 1400 ip tcp adjust-mss 1360 keepalive 5 3 tunnel source 192.168.0.34 tunnel destination 192.168.0.2 interface GigabitEthernet0/1 ip address 10.0.96.1 255.255.255.0 secondary ip address 192.168.0.34 255.255.255.252 interface Vlan2 ip address 192.168.96.2 255.255.255.0 interface GigabitEthernet0/0/1 switchport access vlan 2 no ip address ip route 0.0.0.0 0.0.0.0 10.96.96.2 ip route 192.168.1.0 255.255.255.0 10.96.96.2
Central site config:
interface Tunnel3 bandwidth 10000000 ip address 10.96.96.2 255.255.255.252 ip mtu 1400 ip tcp adjust-mss 1360 tunnel source 192.168.0.2 tunnel destination 192.168.0.34 interface GigabitEthernet0/1 ip address 192.168.1.2 255.255.255.0 secondary ip address 192.168.0.2 255.255.255.252 ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0/0 overload ip route 0.0.0.0 0.0.0.0 PUBLIC_IP ip route 10.96.96.0 255.255.255.252 10.96.96.1 ip route 192.168.96.0 255.255.255.0 10.96.96.1 access-list 106 permit ip 192.168.96.0 0.0.0.255 any access-list 106 permit ip 10.96.96.0 0.0.0.255 any access-list 106 permit ip 192.168.0.0 0.0.255.255 any access-list 106 permit ip any any route-map SDM_RMAP_1 permit 1 match ip address 106
From Brach I can ping hosts on the central site, and brach hosts from central. Trace shows traffic going though the tunnel correctly, but when I try to ping 8.8.8.8 from the branch i get a time out and trace from branch gets to central and then * * * so I'm guessing that either outgoing traffic is not being natted correctly or that the response is not betting correclty routed. Any ideas?
07-09-2014 12:10 PM
I was missing:
ip nat inside
in the tunnel interface.
07-09-2014 02:14 PM
Thanks for posting back to the forum and telling us how you solved your problem. It is helpful when we have read about an issue to be able to see the solution to the issue.
Rick
