Routing isse.
maahiraahi
Could any one guide for configuring the devices shown in the dia.
I need to configure the following things
1.Need to run EIGRP between all the 4 devices,
2.Need to publish 50 & 51 segments on Router R1
3. Need ot publish 52,23,&54 segments on router R2
if Telco 1 fails all the segments should publish on Router R2,
IF Teclo 2 fails all the segments should publish on router R1
Thanks in advance
rm
paolo bevilacqua
1. no diagram attached.
2. non-standard terminology. What "publish" means ?
3. do you command routing basics? You want someone else to configure for you (even free) then you don't understand what was done ?!?
maahiraahi
missed the attachment , sorry for same.
posted another the same with diagram .
sorry for inconvinence.
