Routing platform with 10Gbs interfaces
Colin Higgins
Level 2
Level 2
I am looking for a Cisco router, or maybe Nexus platform, with 10Gbs interfaces as an option. I require 4 per unit.
I didn't see a whole lot in the product listing, save for the high-end CRS stuff. I need something that is ideally under 4U in size and supports MPLS, etc.
Any recommendations?
2 Accepted Solutions
Mark Malone
Have you looked into ASR 1000 models could be an option , some of them have 10gb ints
http://www.cisco.com/c/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/datasheet-c78-731632.html
Seb Rupik
In addition to the ASR you could take a look at the 4500-X :
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-x-series-switches/data_sheet_c78-696791.html
...you'll get better port density than an ASR and it will be significantly cheaper, although the 4500-X does perform some operations in software (GRE encapsulation springs to mind).
We opted for three WS-C4500X-32SFP+ to connect our 10GB ISP links at my last employer.
cheers,
Seb.
Mark Malone
Seb Rupik
cheers,
Seb.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Just to add a bit to Mark's and Seb's posts.
An ASR1004 is, I believe, the smallest ASR1k that would support 4 10g interfaces.  It also appears it will support the recent 6x10g card.  Feature wise, it's likely a more capable device vs. a L3 switch.
In the Catalyst line, besides the 4500-X, there also the recent 6840-X.
