Routing problem or not?
bradlesliect
I need to connect Site A to a host on C. This both connect to my network which is site B
There is a route from Site B to site C but when I do a 'show ip route' for that particular host from Site A, I get "% Network not in table"
When I do a traceroute to host from Site A, it dies on the interface that Site A connects to on Site B. When I do 'show ip route' for the host(Site C), it knows how to get there.
Coincidently, both sites A and C are connected to the same router on site B.
What other information can I give you to help me solve this problem?
5 Replies 5
smothuku
Level 7
Level 7
HI ,
Yes it is routing issue.
Just give the following ip route on site A.
ip route 0.0.0.0 0.0.0.0
Hope this resolves your problem.
Another solution.
Add the routes to site B and site C on site A router.You need to add two routes on site A router.One is for Site B and other one is for site C' lan range.
If you add default route on site A , no need to add two routes mentioned in second step.
satish
I already have a default route statement on A pointing down the serial interface to site B.
A show ip route of the host I'm trying to connect to at Site C, shows me that this router knows how to get to the host at Site C.
When I do show ip route (Host IP on Site C), I get '% Network not in table'. Should the default route 'ip route 0.0.0.0 0.0.0.0 Serial0' not take care of this?
What am I missing / not seeing?
Hi Brad
Does site C know how to route back to Site A ?
Jon
Hi Jon,
According the the administrator they do. I dont have access to site C router or their firewall. Will need to pose the necessary questions tomorrow.
What else do I need to ask?
Hi Brad
Is the firewall in the path of the traffic from site A to site C. If so they will need to confirm they are allowing icmp through to hosts in Site C.
If not they need to confirm they have a route back to Site A's subnets or at least the IP address range you are using at Site A.
Jon
