Routing problem with ip unnumbered
Zoltan051
Hi Folks,
I'm pretty new to Cisco's so bear with me. I'm switching my office network to a new internet provider, who gives me 8 ip addresses: xxx.xxx.73.128/29
The ISP requires that I dialup using PPPoE, and use IP unnumbered.
On my side, I use 2 Cisco 2811 ISRs, Network diagram looks like this
WAN, ISP Line
     |     Fe0/1
Router 1
     |     Fe0/0    xxx.xxx.73.129
     |     Fe0/1    xxx.xxx.73.130
Router 2
     |     Fe0/0   192.168.196.1
  LAN  192.168.196.x
Basically router 1 does only the PPPOE dialup, Router2 is my pre-existing router and does the NAT, firewall, ipsec tunnel to other office and stuff. Once I'm comfortable with the config I'll consolidate all to router 2 only, but having router 1 allows me to experiment with the config without endangering the old, stable config on router 2.
Problem is: Router 2 can't ping router 1 and vice versa, nor can I ping router 2 from the WAN. Yet for some reason, the ipsec tunnel on router 2 manages to go up. Machines on the LAN can access other offices via the tunnel, but cannot access the internet any more.
Router 1 does the dialup and accesses the internet just fine.
Here are the relevant bits of the configs:
Router 1:
vpdn enable
interface FastEthernet0/0
description =====LAN Interne=====
ip address xxx.xxx.73.129 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no cdp enable
no mop enabled
interface FastEthernet0/1
description =====ISP Line=======
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1
description KDDI WAN Dialer
ip unnumbered FastEthernet0/0
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp chap hostname -----
ppp chap password 7 ---
ppp pap sent-username -----
ip route 0.0.0.0 0.0.0.0 Dialer1
Router 2
interface Tunnel1
ip address 10.255.0.196 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication ------
ip nhrp map multicast dynamic
ip nhrp map multicast --------
ip nhrp map 10.255.0.1 --------
ip nhrp network-id 1
ip nhrp nhs 10.255.0.1
ip tcp adjust-mss 1360
ip ospf network broadcast
ip ospf cost 100
ip ospf priority 0
qos pre-classify
tunnel source FastEthernet0/1
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile DMVPN_Profile
description =====LAN Interne=====$ETH-LAN$$FW_INSIDE$
ip address 192.168.196.3 255.255.255.0
ip access-group LAN_IN in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no cdp enable
no mop enabled
description =====Liaison Internet=====$FW_OUTSIDE$
ip address xxx.xxx.73.130 255.255.255.248
ip access-group WAN_IN in
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect FLOW_IN in
ip inspect SDM_LOW out
ip nat outside
ip route-cache flow
duplex auto
speed auto
no cdp enable
no mop enabled
service-policy output QoS
router ospf 1
log-adjacency-changes
network 10.255.0.0 0.0.0.255 area 0
network 192.168.196.0 0.0.0.255 area 0
distribute-list FILTER_OSPF in
ip route 0.0.0.0 0.0.0.0 xxx.xxx.73.129
ip nat inside source list NO_NAT interface FastEthernet0/1 overload
spremkumar
Level 9
Level 9
hi
can you paste the access lists named WAN_IN here ?
regds
6 Replies 6
spremkumar
Level 9
Level 9
hi
regds
Silly me - indeed the pb was in access list WAN_IN, not a routing issue at all! All working now, thx!
Correct me if I'm wrong but it should be OK to get rid of the 1st router altogether, right? I could create the dialer1 interface on router 2, plug the ISP line on FE0/1, and have the router's public IP xxx.xxx.73.129 on a Loopback interface...
Anyway, I'm going to leave it like this for the time being. Lucky I had that second 2811 ISR on hand...
Can you post the show version output of both the routers here ? so that we can check out whether you can remove off the first router from your network and directly connect the pppoe link onto the second router
regds
Here goes: it's exactly the same for  both. Both routers have 11 FastEthernet intefaces Currently using 2 on each
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(19b),
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 13-Jun-08 04:12 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
--------------------- uptime is 6 hours, 19 minutes
System returned to ROM by reload at 03:43:10 UTC Fri May 14 2010
System image file is "flash:c2800nm-advsecurityk9-mz.124-19b.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FHK0915F1GT
11 FastEthernet interfaces
1 ISDN Basic Rate interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
If you were already having a 2811 then why did you go for another 2811 ? i thought you might have some 800 series router which you are looking to get replaced using with 2800 series one.
any specific requirement in place to have 2 routers out there in your network ?
regds
I just had that second 2811 on hand as a backup so I used it. I didn't want to cause too much downtime on Router 2 to experiment with the config.
Ideally in the long run the configuration would be a single 2811 router, or coupled with a 800-series router to do the Pppoe connection. The reason for having two 2811 in the first place was to have a backup if one breaks down.
