Routing Problem
lgomezvinoteca
I have attached the next cisco configuration.
I have two Wan interfaces on my cisco, I want to configure the output of all the inside traffic for the DSL Dialer1 interface and the access for my public IP Address (http, mail, dns) for the serial interface.
I have been working with this configuration using EIGRP, but yesterday it stops working fine, If I configure the output for the Dialer1 all my public IPs address of the serial interface are not accesible.
What could be the cause of this problem, or what can be the best configuration to do it?
The IP 220.52.4.201 is the global ip for all the output traffic of the PIX Firewall
ip subnet-zero
controller E1 1/0
framing NO-CRC4
clock source internal
channel-group 0 timeslots 1-8
interface ATM0/0
mtu 1492
bandwidth 2048
no ip address
ip nat outside
no ip route-cache cef
no ip route-cache
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0.1 point-to-point
description atm0.1
bandwidth 2048
ip nat outside
no ip route-cache
pvc 8/35
pppoe-client dial-pool-number 1
interface FastEthernet0/0
ip address 220.52.4.193 255.255.255.240
ip nat inside
no ip route-cache
no ip mroute-cache
speed auto
interface Serial1/0:0
bandwidth 512
ip address 220.52.15.14 255.255.255.252
no ip route-cache
max-reserved-bandwidth 98
interface Dialer1
description DSL
mtu 1492
bandwidth 2048
ip ddns update hostname xxxx.no-ip.org
ip ddns update xxxxxx
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp header-compression iphc-format
no ip mroute-cache
dialer pool 1
ppp authentication pap callin
xxxxxxxxx
xxxxxxxxx
xxxxxxxxx
ip rtp header-compression iphc-format
router eigrp 100
network 0.0.0.0
auto-summary
access-list 107 permit ip host 220.52.4.201 any
access-list 107 deny ip any any
no ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Serial1/0:0 100
ip route 220.52.0.0 255.255.240.0 Serial1/0:0
ip route 220.56.64.0 255.255.240.0 Serial1/0:0
ip route 220.56.80.0 255.255.240.0 Serial1/0:0
ip route 220.76.192.0 255.255.224.0 Serial1/0:0
ip route 220.94.192.0 255.255.224.0 Serial1/0:0
ip route 205.140.0.0 255.255.224.0 Serial1/0:0
ip route 205.140.32.0 255.255.224.0 Serial1/0:0
ip route 205.158.128.0 255.255.224.0 Serial1/0:0
ip nat inside source list 107 interface Dialer1 overload
hitesharora
Your eigrp configurations seems to be wrong as it is showing network as 0.0.0.0. On which interfaces you are running eigrp.
Rgds.
