Routing protocol for MPLS
tecnetpro
We are planning to implement MPLS connectivity between our 3 offices and data center. Data center will have a access port of bandwidth 34 Mbps and other 2 offices with 10 Mbps and one office with 2 Mbps bandwidth.
From each office the MPLS is connected to Service provider Cloud.I have a choice of 3 routing protocols to use from the service provider.RIP II,OSPF,BGP.Which routing protocol to be used ?i have 2811 routers at each site.Is this fine ?I prefer to use OSPF but how in how many areas ?Is it fine to use a single area when service provider cloud is involved ?
Giuseppe Larosa
you can use a single area design but I would prefer to use a non backbone area in each site with your CE router acting as ABR the whole SP cloud will be your area 0 backbone.
This because OSPF routes from other sites are imported as O IA not as O routes.
So it is better to reflect this on the OSPF topology.
Support of OSPF over the cloud is emulated via multi protocol BGP specific extended communities.
I would also consider to use BGP, being the easiest thing for the provider could have a lower price (but I understand they have given you three options at the same price).
I wouldn't consider RIP v2 in any case
Hope to help
Giuseppe
i will have 2811 router on each site connecting to PE.my each 2811 site router will be a ABR with separate area connecting to a backbone area 0 on PE.am i getting it rt ?Can you please detail this ?.
an example can be
net 172.16.0.0/16 internal to site
net 192.168.1x.0/24 backbone link on PE-CE
net 192.168.254.x/32 loopback in area 0
int loop0
ip address 192.168.254.x 255.255.255.255
desc OSPF router-id
router ospf 10
router-id 192.168.254.x
network 192.168.1x.0 0.0.0.255 area 0
network 192.168.254.x 0.0.0.0 area 0
network 172.16.0.0 0.0.255.255 area 1x
where x changes on each site: 1,2,3
Hope to help
Giuseppe
thanks for the reply.letme try this.
