Routing question on ASA 5510
joseph
Good Morning,
Is there a way on the Cisco 5510 Security Appliance to enter some routing that would route a specific Private IP to a Specific Public IP.
Specifically...
Route 10.1.0.23 to 159.xxx.xxx.20 ?  I need everything sent on 10.1.0.23 to go to 159.xxx.xxx.20.
I need to do this for about 15 addresses and I have learned that I cannot just redirect the entire 10.1.0.0 subnet to a specific IP.
Any help sure is appreciated.
--Joe
Jon Marshall
joseph@sec.state.vt.us
Good Morning,
Specifically...
--Joe
Joe
Sorry but no you can't do this for the same reasons i explained before. If you have to do this then you need a router and not an ASA.
I know this isn't what you want to hear but your device just can't do that.
Jon
Jon Marshall
Good Morning,
Specifically...
--Joe
Joe
Jon
Jon,
I was afraid that would be the case.  I was looking at the routing tables with the Show Route command and thought perhaps there was a way, after all, it has other routes.
How can something this easy be so difficult.
--Joe
