Routing Question
melry88
Hey All,
This one maybe a tough one, I have a friend trying to break protocols across two lines. He wants his IP phone traffic to use a T-1 and his other traffic to use his 10mb wireless. Can you route via tcp and udp ports to one remote subnet?
Thanks!
s_bandkar
I might be rushing in as solution. but would suggest to route IP Phone traffic using router map command and putting in set interface .
glad to tell you more .. request you to just share the config so we can drill in more .
also we can use some policy map to give priority to the ip phone traffic.
Satyajit
lgijssel
Level 9
Level 9
This type of problem can be solved using policy routing. Define an access-list for the IP phone and set the next-hop to the T1-remote side. The route-map looks like this:
route-map IPphone permit 100
match ip address 105
set ip next-hop 10.1.49.1
On the coresponding interface you activate policy routing as follows:
interface (whatever)ethernetXXX
ip policy route-map IPphone
Leo
